Adhering Foam Board To Coooold Walls - Insulation - DIY Chatroom Home Improvement Forum
Old 01-03-2014, 12:35 PM   #1
Rewards Points: 1,076
Adhering foam board to coooold walls
I'm (still!) in the process of attaching 1" XPS foamboards to my basement walls for insulation. Right now it is wicked cold outside (-2 F without the wind chill this morning!), so the cinder block wall areas in my basement that are above ground are quite cold as well. Will the foamboard adhesive be affected any if I glue the boards up while it's bitterly cold outside? I figure the heat from inside my house should make up the difference, but I wanted to be sure.
spaceman spif is offline   Reply With Quote
Old 01-03-2014, 12:39 PM   #2
bbo
what does the adhesive say?
the Loctite stuff wants the surface clean, dry and between 40 and 100 f.
http://www.loctiteproducts.com/p/pl_...d-Adhesive.htm
bbo is offline   Reply With Quote
Old 01-03-2014, 12:43 PM   #3
That's what I'm using for adhesive. I haven't actually measured the temperature of the wall, but I know last night it felt cold to the touch and today it's even colder. Safe to assume it's above 40 on the surface of the walls, but not by much, and I didn't know if anyone had experienced problems gluing on to cold walls and would recommend setting up a heater in the room.
Old 01-03-2014, 12:55 PM   #4
bbo
I'd use a heater ( one that puts out dry heat, a propane heater would make it too wet IMO ) I think the cold and condensation would be an issue.
I think if you get it to stick and the foam doesn't fall, that's all you need. worst case, you'll have to stick some back up later, right?
Old 01-03-2014, 11:46 PM   #5
Registered User
Rewards Points: 526
The initial bond should not break to allow air behind the FB. It HAS to be air-tight on the CMUs to prevent condensation there. IMO, use 1' square grid pattern to limit any future air leaks to that small area, not to compromise the whole. http://joneakes.com/jons-fixit-database/743
Your local AHJ may also require positive attachment (mechanical fasteners)- other than adhesive, many do.
Gary
Old 01-06-2014, 09:25 PM   #6
When I did the first wall, I applied the adhesive in 1' "grids". Well, some looked more like 1' "connected amoebas". I plan on doing the same with this wall. Right now it's -10 F (without the wind chill) so I plan on waiting a few days just to be safe before I glue the second wall.
As for fasteners, if I plan on putting up studs for drywall in front of the XPS, do I still need to mechanically fasten the XPS to the cinder block?
Old 01-06-2014, 10:06 PM   #7
Rewards Points: 6,652
Go get a couple of shop heaters. It will warm that room up in no time. I was running two 1500 watt heaters in my basement, and within four hours, it went from 54 down there, to 68. Of course the furnace also was cycling every now and then.
This unit is $170 at Menard's http://www.menards.com/main/heating-...857-c-6328.htm 5000 watt, 240vAC, 21 amp.
The great thing is that after you get done with the basement, you can hang it in your Garage, to keep it warm when you are out there working.
Installing deck ledger board over foam board? RickT Building & Construction 9 04-27-2018 11:41 AM
Installing foam board around windows ? Arky217 Windows and Doors 3 09-12-2011 04:13 PM
fiberglass over rigid foam board in cantilever? KatieAK Building & Construction 3 11-17-2009 07:48 PM
wall sheathing, foam board, insulation and house wrap dr.demento Building & Construction 10 10-18-2007 04:42 PM
Walls on top of particle board that got wet Bruno2000 Flooring 2 08-24-2007 02:30 PM
