Adding More Insulation. - Insulation - DIY Chatroom Home Improvement Forum
Old 01-07-2015, 08:26 PM   #1
Rewards Points: 20
Adding more insulation.
My house has the rockwool insulation in the attic. If I threw some fiberglass on top of it with that improve the insulation? Or would it be better to take it out and replace it?
DollarStretch is offline   Reply With Quote
Old 01-07-2015, 08:46 PM   #2
Davejss's Avatar
Rewards Points: 1,100
If the rockwool is full up to the tops of the joists I would run fiberglass batts across perpendicular to the joists. If not, I would add some more first and then another layer across. You may need to add baffels in your rafter bays to avoid ice dams. I don't know where you live, so I can't tell you how much insulation that you need. But you can do a quick search and you'll find the required R-Values for attic insulation in your area. If done properly, bringing your attic insulation up to where it should be will give you a noticable differance in your heating and cooling.
Davejss is offline   Reply With Quote
Old 01-08-2015, 08:09 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 766
How much insulation do you have currently? There is a diminishing long returned when he comes insulation thickness.
The best thing you can do is the air seal the attic floor and make sure that the home is losing its conditioned air to the unconditioned attic.
In the process of addressing those items, be sure to preserve the ventilation pathway as Dave mentioned and then you can either roll out additional fiberglass bats or blow in additional insulation.
Blown in insulation is usually a bit easier to manage and when done properly, provides more uniform coverage.
Looking for expert advice for adding insulation under a gas fireplace MileHigh80228 Insulation 14 12-11-2012 01:12 PM
insulation -- adding cabinets in knee wall flamtap Insulation 11 08-27-2012 08:06 AM
Adding panel insulation and metal roofing Ben gilmore Roofing/Siding 1 04-02-2012 07:24 AM
Adding attic insulation rakuz66 Insulation 4 07-22-2011 05:02 PM
Adding Insulation jamiedolan General DIY Discussions 1 09-08-2008 01:43 PM
