Adding Insulation Baffle Between Rafters - Insulation - DIY Chatroom Home Improvement Forum
Old 10-12-2015, 07:04 PM   #1
Lord of Slums
Rewards Points: 1,974
Adding insulation baffle between rafters
I want to add those foam egg crate baffles between the rafter bays. My main question is what do I do in the bays that have those turtle vents? Do I just go right over them? I prefer to do every bay
mj12 is offline   Reply With Quote
Old 10-13-2015, 10:33 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
What kind of attic is it? Are the turtle vents located near the eave in this case?
Old 10-13-2015, 09:54 PM   #3
Lord of Slums
metal can vents. Up as high as they can go
Old 10-13-2015, 11:19 PM   #4
Rewards Points: 906
How far are you running the baffles up?
If its a vented attic, no need to run them any further than up past the insulation levels.
Attic insulation in between rafters Laguinaga Insulation 8 12-01-2013 09:34 AM
adding insulation on top of drywall terry hinkley Insulation 2 06-14-2011 04:55 PM
adding xps insulation to the out side of a mobile home Fred84 Insulation 2 05-07-2011 11:10 PM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 10:50 AM
Is adding insulation in attic cost effective? AllGoNoShow Building & Construction 1 12-05-2006 11:31 AM
