Adding Insulation To Attic - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree7Likes
Old 07-25-2019, 06:25 AM   #16
Rewards Points: 92
Re: Adding insulation to attic
Dave, just to note, some air leaks originate in the basement or crawlspace and if accessible, like around a chimney or plumbing, some air leakage reduction can benefits can be achieved from down there.
As you learned and many future readers need to understand, air seal before burying the attic in insulation. But R-60 is nice.
Bud
Dave Sal likes this.
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 07-25-2019, 11:34 AM   #17
user_12345a's Avatar
Rewards Points: 38
When I bought my house back in 1980 (new construction) there was a minimum amount of blown in insulation in the attics. I'm guessing maybe R15 in some areas and R11 in others. It was not distributed evenly and there were some voids as well.
Voids have a disproportionate impact on on heat loss so you can see major savings getting rid of them.
Don't get me wrong - adding is always beneficial, but sometimes there are bigger savings to be had elsewhere.
Every house is going to be a bit different.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 07-25-2019, 12:59 PM   #18
Dave Sal's Avatar
Rewards Points: 16
Bud
Agree. Before I added the last batch of insulation in the upper attic I found a pretty large area around the furnace chimney chase coming from the lower level which is 4' below grade. I can't imagine the amount of heat that went up into the attic over the years. I took some sheet metal and cut it to fit around the chimney and sealed it with red heat resistant caulk.
Dave Sal is offline   Reply With Quote
