Add Blown Insulation Or Radiant Barrier? - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 02-11-2018, 11:42 AM   #16
Rewards Points: 412
Re: Add Blown Insulation or Radiant Barrier?
Thanks Porsche!
I can get some radiant barrier fairly affordable off Ebay so will look to install some.
In regards to insulating "duct" work in the attic. As I've read and stated here, you risk creating moisture/mold by wrapping insulation around the duct board or flex duct. However, what about just draping fiberglass (un-faced or faced) insulation over the duct work? Wouldn't that be similar to insulating the roof line but instead you are placing the barrier directly over the duct work?
God Bless,
Ralph
Ralph III is offline   Reply With Quote
Old 02-12-2018, 07:35 AM   #17
Rewards Points: 1,094
Just to be clear I am a fan of the radiant barrier but it is just one piece of the puzzle . You rarely will get hurt by adding more insulation . Had I kept the previous house/garage I would have added more insulation to that garage ceiling as 3 1/2 " R13 is just not enough . In my new garage I will go at least R30 or more PLUS the radiant barrier .
Porsche986S is offline   Reply With Quote
Radiant barrier (should I) simagic Insulation 16 07-07-2014 11:26 AM
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Bathroom Insulation and Vapor Barrier jibennett Insulation 8 02-23-2013 05:58 PM
Blown Insulation vs Blown Fiberglass DRILLINDK Insulation 7 12-18-2012 10:46 PM
Can I use a radiant barrier -or- floor underlayment as a sound barrier on walls? Missnawlins Insulation 2 06-27-2012 01:12 AM
