ACR Tubes Insolation - Insulation - DIY Chatroom Home Improvement Forum
Old 01-09-2015, 02:48 PM   #1
Rewards Points: 4
ACR tubes insolation
I want to insert a 3/4" copper tube for cold air and 3/8" cooper tube for hot air into a 3" PVC pipe underground. I need to insulate the 3/4" copper tube (cold air). Vendor offer FOAM (R-value=2.4) and RUBBER (R-value=3) for insulation.
I read another web-side that I should not put FOAM near heat.
Since I want to run both copper tubes inside the same PVC pipe. I would like to make sure I can use FOAM as insulation in this particular case.
COPPER is offline   Reply With Quote
Old 01-09-2015, 02:59 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 818
How hot is the hot?
Why do you want to use copper?
There are premade units out of PEX that are insulated already.
Old 01-09-2015, 04:02 PM   #3
Rewards Points: 1,858
Letting us in on what it is your really trying to do in totality and not making it a secret makes it a lot easier to make suggestions.
Old 01-13-2015, 10:44 AM   #4
Rewards Points: 4
Question
Copper tubes insulation for Air Conditioner System
I want to insert a 3/4" copper tubes for cold air and 3/8" copper tubes for hot air into a 3" PVC pipe underground.
I nedd to insulate the 3/4"copper tube (cold air). Vendor offer FOAM (R-value=2.4) and RUBBER (R-value=3) for insulation.
I read in another web-site that I should not put FOAM near heat.
Since I want to run both copper tubes inside the same PVC pipe. I would like to make sur I can use FOAM as insulation in this particular case.
Old 01-14-2015, 04:10 AM   #5
An old Tradesmen
Rewards Points: 52
If its just for A/C, the liquid line(small line) should never get above 135F. So if your foam insulation is okay to use on a water heaters pipes, then it will be okay for your A/C use.
The Following User Says Thank You to beenthere For This Useful Post:
Windows on Wash (01-14-2015)
Where to buy large diameter concrete tubes? ModernDayDarwin Concrete, Stone & Masonry 13 05-18-2013 10:09 PM
Replacing T5 HO tubes with HE BornYesterday Electrical 11 07-27-2012 08:08 PM
Three tubes on drinking water faucet Cinci-Hal Plumbing 6 01-02-2012 01:35 PM
Flourescsent Tubes Dying Mystery wallix Electrical 14 08-24-2011 12:51 AM
Sinking footing tubes Farmer Z Building & Construction 19 11-17-2009 08:50 AM
