3" Ridgid Overtop Concrete Floor - Insulation - DIY Chatroom Home Improvement Forum
Old 01-30-2016, 06:11 PM   #1
Rewards Points: 12
3" ridgid overtop concrete floor
good evening everyone , im looking for a experts answer one this question . heres what I would like to do
I have a small area in my home under my interior stairs and landing that has no heat to it and use it as a storage area , we find this space cold a it make the tile floor on or landing cold also , the walls under the stairs are well insulated I would like to just lay ridged insulation right over top of the slab is that a good idea or am I asking for moisture ad mold that way , thanks in advance
carp130 is offline   Reply With Quote
Old 01-30-2016, 06:58 PM   #2
PE Mechanical Engineer
Thunder Chicken's Avatar
Rewards Points: 892
If you have no heat to the area, insulating the slab won't change the temperature of the floor. You might do better to insulate the underside of the tile floor.
Thunder Chicken is offline   Reply With Quote
Old 01-30-2016, 09:06 PM   #3
Rewards Points: 222
Tape down a 3' square of plastic and leave it for a week to see if any moisture shows up underneath. If bare concrete you may only see a change in color, darker. If you try just 1" rigid insulation, it has a low permeability so it can allow some evaporation through it as opposed to the moisture accumulating under a vapor barrier.
But, any isolated space like that will eventually cool to equalize the heat flow into that area to match the outflow. Adding a louver to the door might increase the heat into the space. Any heat source, even a light, would make a difference.
Bud
Bud9051 is online now   Reply With Quote
Old 01-30-2016, 09:14 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 928
Get some conditioned air in there and while insulating the floor will help, you would want to look critically at the ribbon/band board areas as well for proper sealing.
Can we live in enclosed carport with no vapor barrier under concrete floor? renoven Building & Construction 28 11-03-2014 09:55 PM
Gravel Garage Floor To Concrete Floor... Koldhammer Concrete, Stone & Masonry 8 07-11-2014 07:59 AM
Engineered hardwood over vinyl tile - am I being unreasonable or am I getting screwed photopeter Flooring 25 02-01-2014 11:41 AM
Basement concrete floor repair estimate ControlTech Building & Construction 1 04-10-2010 07:28 AM
Join Wood Cyc Ramp to Concrete Floor Bigboots Building & Construction 3 11-27-2007 09:52 PM
