What Type Of Irrigation Should I Use For A Retaining Wall? - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 05-09-2017, 05:39 PM   #1
Rewards Points: 640
What type of irrigation should I use for a retaining wall?
The retaining wall is going to be 24 feet long and 2ft wide and 2 feet high.
Should I use a drip system or a soak system?
dannieboiz is offline   Reply With Quote
Old 05-09-2017, 06:19 PM   #2
Civil Engineer
Rewards Points: 5,246
Re: What type of irrigation should I use for a retaining wall?
Where I live, most retaining walls are concrete block. You can water them from Boston to San Francisco and not much is going to grow on them. What type of retaining wall do you have?
Old 05-09-2017, 07:35 PM   #3
Rewards Points: 640
The wall is going to be concrete blocks building against redwood fence with 2x12 PT wood against the fence the lined inside perimeter with 6mil plastics.
Old 05-17-2017, 01:59 PM   #4
davittdriveways's Avatar
Rewards Points: 6
According to me you can use drip system.
davittdriveways is offline   Reply With Quote
The Following User Says Thank You to davittdriveways For This Useful Post:
weekendscrub (06-01-2017)
Old 07-30-2017, 04:22 PM   #5
Rewards Points: 84
I have almost the exact same thing and I'm using drip.
It's the most economical way to do it and save water in the long run. I am using a blank tubing and punching in holes into the drip myself.
bondra76 is offline   Reply With Quote
Retaining wall for driveway extension NewHomeDIYGuy Concrete, Stone & Masonry 24 11-17-2015 05:46 PM
surface drainage above a retaining wall Benjamin5 Landscaping & Lawn Care 4 09-26-2015 02:44 PM
French Drain Behind Retaining Wall Tom5151 Landscaping & Lawn Care 0 08-05-2011 01:01 PM
Retaining Wall Demolition --HOW? tdrumm Landscaping & Lawn Care 12 03-20-2011 02:32 PM
Low Retaining Wall cibula11 Landscaping & Lawn Care 3 07-29-2007 12:02 AM
