Sprayed Roundup On An Area... Can I Till It Up And Garden There? - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Like Tree2Likes
  • 1 Post By chandler48
  • 1 Post By tireshark
Old 05-12-2018, 12:21 PM   #1
Rewards Points: 476
Sprayed roundup on an area... can i till it up and garden there?
Edit: It's not roundup, but a similar product that is supposed to prevent growth for a year.
Have a small section of land where I sprayed this stuff on it. Tenants later asked if they could put a garden there. If I till the ground up thoroughly, will it still affect anything they plant?
https://www.orschelnfarmhome.com/bar...107317904.html
tireshark is offline   Reply With Quote
Old 05-12-2018, 01:51 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 4,296
Re: Sprayed roundup on an area... can i till it up and garden there?
Glyphosphate (Round up) is systemic to the plant it touches and travels no further in the ground. I have no idea what the chemical make up of Barrier is, and it may very well sterilize the ground, unlike Round up.
Mike Milam likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
tireshark (05-12-2018)
Old 05-12-2018, 02:08 PM   #3
Rewards Points: 4,310
It's the same chemical, glyphosate. Look up the name, including Gordon's, & SDS which is Safety Data Sheet. Leave out the website name. You can do that for every legal chemical product. I'd give you the link but am on a bad cell phone.
Nik333 is online now   Reply With Quote
Old 05-12-2018, 02:19 PM   #4
So it works like Roundup but they won't release the concentration, may be much stronger. Maybe they could make raised bed gardens? Or pots.
Old 05-12-2018, 02:49 PM   #5
Oso954's Avatar
Rewards Points: 1,982
It says it prevents vegetation growth for up to a year, so itís more than just roundup.
While tiling might reduce the year (mixing deep untraeated earth with the heavy treaded earth at or near the surface) I would wait a year for direct planting.
As NIK said, raised beds or pots would be the solution, with imported soil or planting mix. Or, some other area that you did not spray.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Old 05-12-2018, 03:10 PM   #6
Originally Posted by Oso954 View Post
It says it prevents vegetation growth for up to a year, so it’s more than just roundup.
Sorry, I have been reading up on it, but had to change computers. The long acting ingredient is Imazapyr which other websites say can work for several years. There are warnings about the effect on animals.
BARRIER
ģ
Year-long Vegetation Killer Concentrate is a nonselective
herbicide which kills most annual and perennial grasses, broadleaf
weeds, vines, brush, and trees. The product is absorbed through
leaves, stems, and roots and moves throughout the plant. Treated
plants stop growing soon after application. BARRIER
ģ
Year-long
Vegetation Killer Concentrate will also provide residual control for up to
12 months in the treated area. Heavy rainfall will reduce the length of
residual control. Heavy clay soils may increase the length of residual
control.
It's made in Missouri but I would bet California doesn't allow it except for forestry uses. Just a bet.
Edit: Not for sale in AK, CA, CT, HI & WA.
Interesting lawsuit in Calif. Vineyard sues Railroad for affecting orchards.
https://www.mercurynews.com/2018/01/...herbicide-use/
The Following User Says Thank You to Nik333 For This Useful Post:
Old 05-12-2018, 03:14 PM   #7
Rewards Points: 476
Thanks for all the great info everybody. I just ended up picking out another spot for them to put it, to be safe.
Nik333 likes this.
Decorate Garden with Waste Material julia_garden Interior Decorating 1 05-12-2018 04:15 AM
Retaining wall for garden on sloped yard Leonidsg Landscaping & Lawn Care 27 03-30-2014 09:55 PM
Should I till my yard before planting a flower garden? shannonb Gardening Forum 10 11-16-2010 08:00 PM
New lawn + garden - garden is now a swamp Frozinite Landscaping & Lawn Care 8 09-15-2010 07:23 PM
raised garden on septic tank Rae Landscaping & Lawn Care 4 04-27-2010 10:27 AM
