Soil Testing - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Like Tree2Likes
  • 1 Post By SeniorSitizen
  • 1 Post By Msradell
Old 05-26-2018, 02:37 PM   #1
Rewards Points: 4,364
Soil testing
Has anyone compared the results of a $6 soil test from the hardware store to the one you send away for $40?
Granted, some wouldn't like to do the simple experiment, but possibly the lab uses the same reagents.
Opinions?
Nik333 is offline   Reply With Quote
Old 05-26-2018, 02:59 PM   #2
Guapo
Rewards Points: 11,950
Re: Soil testing
We don't know if they test for the same things. Can you be more specific? What tests do you want?
Guap0_ is offline   Reply With Quote
Old 05-26-2018, 03:26 PM   #3
Re: Soil testing
I don't want anything, I'm just curious since so many Diyers want good soil. My thought is that the send-away labs probably use the same chemicals/reagents as the hardware store test. But if we search it, there will be a sales pitch most likely.
I wondered if anyone had compared them. I may have to do it myself.
Old 05-26-2018, 03:36 PM   #4
Guapo
Re: Soil testing
Most likely. Both the store kit & the mail order people should tell you what tests are included. If not, you may have to make a few phone calls. There shouldn't be any deep secrets.
Old 05-26-2018, 03:46 PM   #5
Re: Soil testing
Sorry, maybe I wasn't clear. For example, is the phosphorus high on both? Is the pH reliable? We did short chemical tests & dipsticks for years before they became available in the stores.
I bet they're pretty close.
Old 05-26-2018, 04:01 PM   #6
Guapo
Re: Soil testing
So you're comparing the results between the 2. I was thinking that it's more like blood tests where you can request just a CBC or an SMA 20 or more inclusive tests. In that case the $6 store test would be limited like the CBC & nothing else.
Old 05-26-2018, 04:26 PM   #7
Rewards Points: 1,590
Re: Soil testing
Opinions?
Since I wanted the basics, I ask my daughter just what you are asking. She is a biochemist, microbiologist, has worked in a lab doing this testing and other tests that would make some people's head spin. Mine for sure.
She ask if I wanted her to draw molecular structure diagrams or some such stuff and any other testing for an extra charge and I said no thanks. Her suggestion for what I needed was go to WallyWorld and buy a kit.
That test and the soil make-up structure test ?? with the pickle jar is about my limit.
At least I know my limits most of the time when talking to her. She questions anything I try to snow her with.
Nik333 likes this.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Nik333 (05-26-2018)
Old 05-26-2018, 04:52 PM   #8
Re: Soil testing
Yes, but I don't want arsenic levels. For the guy with the lawn on a hill; he could test more areas.
Old 05-26-2018, 05:52 PM   #9
Rewards Points: 7,606
Re: Soil testing
I have used the McKenzie hardware store kits.
It didn't give any results. My soil must have zero nitrogen, zero phosphorous and zero potash. Probably user error - maybe I dug too deep and got too much clay (topsoil layer is pretty thin on my property). Or used sample with too much or too little silt. Bought more kits and tried again, got a little color, but had no confidence results were meaningful.
All an established lawn wants is nitrogen anyways.
SPS-1 is offline   Reply With Quote
Old 05-26-2018, 06:07 PM   #10
Re: Soil testing
All an established lawn wants anyways is nitrogen anyways.
Mine that looked like Senior's worked well. The second time with a different kit it was harder. I may not have been as patient. I do need to read the directions!
Re nitrogen, I bought a lot of large flowering plants & forgot that the pot's soil was fertilized. I used 10-10-10 & all the flowers fell off & the leaves grew. Too much nitrogen.
Old 05-27-2018, 12:05 AM   #11
Re: Soil testing
But can she fix toilets?
She sounds like she got her humor from you
Old 06-04-2018, 09:26 PM   #12
Rewards Points: 102
Re: Soil testing
Do you have a local nursery that will do the testing for you? Some will do it for free.
gma2rjc is offline   Reply With Quote
Old 06-04-2018, 10:23 PM   #13
Msradell's Avatar
Rewards Points: 832
Re: Soil testing
Find your local state agriculture extension office is. In most states they will do soil testing for free. They will also give you a list of recommendations to improve your soil based on the test results.
Nik333 likes this.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 06-05-2018, 01:24 AM   #14
Re: Soil testing
I actually like doing the tests, wh I'm patient & the weather is nice. The advice for amendments would certainly be helpful & I could compare the results.
Damp soil outside = mildew inside? mc510 Building & Construction 6 09-05-2018 08:21 PM
Soil test andlawn help whoppr Landscaping & Lawn Care 2 10-04-2017 07:36 AM
Radon soil gas, water w/radon, & other household air quality mitigation plans ylekyote HVAC 9 02-08-2016 03:46 PM
clay soil amendments; have you seen this? tstex Gardening Forum 1 08-05-2015 03:30 PM
Compost or top soil requirement cprao Landscaping & Lawn Care 10 12-28-2010 05:01 PM
