Seeking Input On Fence For Sloped Garden - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 07-16-2015, 09:57 AM   #1
Rewards Points: 169
yes, yes I know my garden is pathetic.. but ay I'm a rookie at this.
Anyways, saw this morning that some critter(probably rabbits right?) ate half of my crop...
For 5 weeks it was fine and they never ventured up into the "garden" area so I let them hang in my garden... NO MORE!
However I can't be out there 24/7 so I need some kind of fence to keep the critters away..
Having never built a fence much less on a sloped garden such as mine I am seeking any and all advice on this.
I have no idea on where to even begin.. i.e. what materials, fence implentation?
I am in the Milwaukee, WI area and have a Home Depot and a Menards 5mins from my home.
please advise
oNe
Sean Price is offline   Reply With Quote
Old 07-16-2015, 10:06 AM   #2
Rewards Points: 169
I should add, nothing fancy or permanent.. just enough to keep the rabbits away and the 2yr, and 4yr old out.
just googled again, found nada.. looked for garden fence on slope, garden fence on a hill, both google and youtube fail me..
hopefully yall can come thru
oNe
Old 07-16-2015, 10:30 AM   #3
Rewards Points: 188
This plus some of the posts would work.
http://m.homedepot.com/p/HDX-40-in-x...D14/204331924/
http://m.homedepot.com/p/HDX-4-ft-Li...4HD/204331911/
Dan
djlandkpl is offline   Reply With Quote
Old 07-16-2015, 11:02 AM   #4
Rewards Points: 169
sweetness!!
thank you sir!!
I'm thinking 6 spikes should suffice right? One on each corner, then one in the middle of each corner..
Old 07-16-2015, 11:31 AM   #5
Rewards Points: 188
The number of poles will depend upon the distance. You can always add more.
Be sure the fence is tight to the ground to keeps the rabbits from sneaking under.
Dan
Old 07-16-2015, 11:59 AM   #6
Low Slope Roofing
Rewards Points: 114
I did T-post and chicken wire. Drive the post in a few inches, and wire the chicken wire to the posts.
1985gt is offline   Reply With Quote
Old 07-16-2015, 01:13 PM   #7
Rewards Points: 7,003
I would suggest you cough up the $2-3 extra for the heavy duty T-post. The ones shown bend pretty easy and may even do as you drive them in.
Since you said you were new fencing, I suggest a shallow trench along the propose fence line level (as in a straight line) the ground and to help keep critters from going under.
When you stretch the wire the ends will need to be cut on angle. It may be easier to do a couple of the middle posts and stretch towards each end not doing the final end cuts until it is stretched.
HD and Lowes also sell pre-bent wire ties for regular fencing. It may or may not work with that tight of a mesh.
Your gate can be a simple gap gate, just wire loosely fastened on one side and secure on the other.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
3.5ft front yard fence (DIY) splintner Landscaping & Lawn Care 10 03-07-2014 07:24 PM
Need help with shady fence installers! paddles Building & Construction 10 10-10-2013 10:39 AM
? Regarding Building a Fence (Posts + Stain) PolishPete Carpentry 0 08-20-2013 01:03 PM
Reuse Concrete Fence Post Pier & Fence Post Extraction JasonCA Landscaping & Lawn Care 2 03-24-2012 08:58 PM
How strong are fence posts? Suggestions? Thoughts? johnluk Building & Construction 8 06-01-2009 07:37 PM
