Sculpting A Rhododendron - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 04-11-2018, 09:33 AM   #1
Rewards Points: 324
Sculpting a Rhododendron
I'd like to sculpt this rhododendron to be more aesthetically appealing. I guess that's a broad statement.
Any landscapers here have advice?
Should I try to move it away from the house a bit?
Trim the lower branches? Or maybe, like tie a rope around the lower branches to attempt to train them to grow 'up' rather than 'out'?
Fisher1871 is offline   Reply With Quote
Old 04-11-2018, 10:00 PM   #2
Msradell's Avatar
Rewards Points: 826
Re: Sculpting a Rhododendron
That's the natural shape of most rhododendrons, your biggest problem is it was planted too close to the house when it was 1st planted. Moving it when it's that big is going to be a major project and you most likely will kill it. I would just trim off the top a little bit and let it be.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
Fisher1871 (04-12-2018)
Old 04-12-2018, 04:49 AM   #3
Naildriver
chandler48's Avatar
Rewards Points: 4,326
I agree, too close to the house originally, and you probably can't successfully move it. Rhodies grow wild here, so we don't plant them decoratively. Definitely trim it away from the house as well as the top. It is in it's normal state, now, so you may not want to replace it with another one, but maybe a boxwood or other shapeable (is that a word?) shrub.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
Old 04-22-2018, 09:10 AM   #4
Rewards Points: 576
Not looking too good.....Is it facing south or west? Seems to have sun scald on 2 sides. Has it always looked like this ?
It can be cut and shaped, maybe. Look carefully for dormant buds/nodes on the stems, under the leafs. Might be some .....and you can cut above them.
Cedrus is offline   Reply With Quote
The Following User Says Thank You to Cedrus For This Useful Post:
Fisher1871 (04-23-2018)
Old 04-23-2018, 07:59 AM   #5
Rewards Points: 324
It is on the 'sunny' side of the house. Pretty much in full blast all day long.
When I purchased the house, a very large juniper tree was blocking most of the sun from the rhododendron.
Old 04-23-2018, 08:17 AM   #6
Rewards Points: 576
My feeling is.....cut it way back, dig it out and transplant...if feasible. If not, cut it down, it will never look good.
