Ryobi Gas Tiller - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 09-15-2015, 06:13 PM   #1
"Old" Newbie
Rewards Points: 177
Ryobi Gas Tiller
I have a 9", 31 cc gas powered rotor tiller. It's put in many years of good service and may have just reached the natural end of it's life expectancy.
Taking it to a pro for repair would definitely cost more than a new one, but I'd like to give it one more chance for revival for sending it to the dump.
Last fall I ran some Stabil treated gas through it and emptied the tank.
Now when I start it, it runs for about 5 seconds and then quits. Acts like it's burning the gas from the priming bulb but not getting gas from the tank. Plan to take it apart and see if I can blow out the gas lines, check any filters, etc. Any other ideas?
Thanks,
Rob
RCrosby257 is offline   Reply With Quote
Old 10-08-2015, 04:50 PM   #2
Rewards Points: 68
I would look up the cost of a new carburetor, that's most likely the problem if it's starting and then stalling. it might be a little cheaper to buy a carb kit and you could clean out the existing carb, but a new carb is most likely only a $10-$25 part and will save you the headache of cleaning it out.
could also be the air filter or the gas lines.
Where in maine are you??
pats12 is offline   Reply With Quote
The Following User Says Thank You to pats12 For This Useful Post:
Colbyt (10-08-2015)
Old 10-08-2015, 05:12 PM   #3
Rewards Points: 7,015
The carbs can be really cheap on Ebay.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 10-08-2015, 05:19 PM   #4
Rewards Points: 68
Amazon too
New Ryobi trimmer, old attachment interchange funflyer Tractors & Mowers 8 05-29-2018 09:57 AM
Ryobi 18v drill smells like #$%^ ZZZZZ Tools 8 11-08-2014 07:43 AM
Ryobi...The Throwaway Tool Company RainPure Tools 14 11-01-2009 08:05 PM
needing Contact info for Ryobi Tools, bad commutator flywelder Tools 2 03-14-2009 06:44 AM
recommendations for an all-purpose drill mcvane Tools 18 11-29-2007 09:12 AM
