Replace Shrubs Or Wait? - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 05-24-2014, 08:31 AM   #1
Replace shrubs or wait?
After a long, rough WI winter these shrubs took a beating. Should I wait and see what happens or are they done?
I forget the name of the first shrub, but the other two I have on one corner of my home.
Replace shrubs or wait?-image-3283408458.jpg   Replace shrubs or wait?-image-100382739.jpg   Replace shrubs or wait?-image-3288062630.jpg
dinosaur1 is offline   Reply With Quote
Old 05-24-2014, 09:50 AM   #2
Here are some better pics of the shrubs.
Replace shrubs or wait?-image-3612525134.jpg   Replace shrubs or wait?-image-402194106.jpg   Replace shrubs or wait?-image-294298941.jpg
Old 05-24-2014, 10:27 AM   #3
Rewards Points: 188
I think they'll make it with some TLC.
Dan
djlandkpl is offline   Reply With Quote
Old 05-24-2014, 11:22 AM   #4
Indepspirit's Avatar
Brown leaves are just a hint of the damage that may have resulted from the cold. All those leaves that are damaged, they’re probably going to shed, when they shed you can clean them up and get them out of the area just in case there are any fungal spores, but for the most part they’re going to shed those leaves and push new growth. So if you prune back anything that’s damaged you may be pruning back live growth for this year.
Wait a few weeks or more before making any decisions. As the weather warms up, plant portions often continue to decline. You may notice stems cracking and bark peeling away as further indication of the cold damage. By the end of this month the extent of the cold damage can probably be detected. Use a knife to scrape along the stems until you find green tissue. This is normally the point where the plant can begin new growth. For some shrubs, the green stems may be found only at the ground. Given time, even these plants can recover rapidly if they have a well-established root systems. Check several branches if you see a good amount of green give it some TLC and let it grow.
Indepspirit is offline   Reply With Quote
Old 05-24-2014, 11:29 AM   #5
Originally Posted by Indepspirit
Brown leaves are just a hint of the damage that may have resulted from the cold. All those leaves that are damaged, they’re probably going to shed, when they shed you can clean them up and get them out of the area just in case there are any fungal spores, but for the most part they’re going to shed those leaves and push new growth. So if you prune back anything that’s damaged you may be pruning back live growth for this year. Wait a few weeks or more before making any decisions. As the weather warms up, plant portions often continue to decline. You may notice stems cracking and bark peeling away as further indication of the cold damage. By the end of this month the extent of the cold damage can probably be detected. Use a knife to scrape along the stems until you find green tissue. This is normally the point where the plant can begin new growth. For some shrubs, the green stems may be found only at the ground. Given time, even these plants can recover rapidly if they have a well-established root systems. Check several branches if you see a good amount of green give it some TLC and let it grow.
So your saying I should leave these blue junipers as is ....even the one that barely has any growth? One I cut back the dead portion there's nothing left.
Old 05-24-2014, 12:30 PM   #6
Since the winter was harder this year I would give them time to "warm up". Around the first week of June see how much green is left on the branches under the bark. If there is still a good amount of green underneath it's still alive and should push out new growth. If there is little green then replace them. Pruning them will not help because when you cut evergreens back to sticks they usually stay that way. If the brown is falling off normally just remove it from the ground. They may not completely fill out this summer so if you are worried about the looks of them for the summer then you might want to replace them.
Can I replace the ADT alarm Concord express 60-806 panel with a DSC 1832 panel? alhome09 General DIY Discussions 0 10-14-2013 09:52 AM
Should I replace my Federal Pacific Breaker Panel? scottgriz Electrical 15 11-23-2012 07:09 PM
Original (?) galvanized water supply pipes replace with PEX, CPVC, copper? TomServo Plumbing 5 11-06-2012 11:07 PM
Old Water Heaters - replace or wait to fail? AB1337 Plumbing 15 09-03-2011 06:57 PM
Pulling up old tile or linoleum to replace it. RyanD General DIY Discussions 4 03-25-2009 12:53 PM
