Remove Tree Stump - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Like Tree3Likes
  • 1 Post By CodeMatters
  • 2 Post By CodeMatters
Old 01-15-2018, 01:57 AM   #1
Rewards Points: 76
Remove tree stump
Hello to all. To remove the old tree stump I tried this solution. I hope you find it useful.
Fatmansat is offline   Reply With Quote
Old 01-15-2018, 10:21 AM   #2
custom user
Rewards Points: 1,820
Re: Remove tree stump
I'll pass. No sense risking buring the fence down, or more. I'd use a stump chipper or chainsaw.
JasperST is offline   Reply With Quote
Old 01-15-2018, 11:51 AM   #3
JUSTA MEMBER
Rewards Points: 4,090
Nah not for me, too big a chance of burning other things up.
I would have set up my A frame and Chain Hoist right over the stump, tied a chain to the stump, and to the chain hoist, and pulled it out.
ED
de-nagorg is offline   Reply With Quote
Old 01-15-2018, 12:05 PM   #4
Property Mgt/Maint
Rewards Points: 6,564
I dig them out with a tractor and back-hoe.
I guess if live in a rural area where neighbors aren't going to complain about a smoldering fire for a few days burning is fine.
Yodaman is offline   Reply With Quote
Old 01-16-2018, 06:14 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Ayuh,.... I burnt out a 6' poplar stump last year, but there was nothin' Close to it, like in the picture,.....
I also found puttin' a fan nearby, helps keep the fire burnin' Hotter, to quicken the time frame,....
Old 01-16-2018, 06:51 AM   #6
CodeMatters's Avatar
Rewards Points: 6,644
Patience isn't my strong suit but stumps seem to be an exception. I have
no issue if it takes 20 years for them to go naturally.
de-nagorg likes this.
CodeMatters is offline   Reply With Quote
Old 01-16-2018, 07:40 AM   #7
Rewards Points: 2,002
Three years ago after paying a pro stump grinder to take down my 3- 16 in.diameter stumps in just twenty minutes, I changed my stump elimination program.
I had five more to get ground down later on, when I cut some trees down. So I used my chainsaw and just vertically "quartered sliced" the stumps down 12 inches below the ground and then crossed cut them level.
Yep, it was lots of work and breaks taken with iced tea by me. But I enjoyed paying myself $10.00 a minute and took my time doing the work. JMO
Gregsoldtruck79 is online now   Reply With Quote
Old 01-16-2018, 07:56 AM   #8
custom user
For a couple I would do some home method but for more I would rent a chipper.
Old 01-16-2018, 08:50 AM   #9
Googling "planter in tree stump" brings up some nice options.
Larryh86GT and de-nagorg like this.
Old 01-16-2018, 09:21 AM   #10
Rewards Points: 1,590
If burning, to speed the process, a chiminea can be made by boring a couple of holes with a long auger bit. 1 hole vertical top center and the 2nd hole low and horizontal to the first hole. The longer it burns the larger the flame.
Old 01-16-2018, 03:03 PM   #11
Rewards Points: 266
I burned out a large stump last year using a propane torch from harbor freight. $40 worth of propane and that sucker came right out. I moved the torch gradually so it basically became a "fire saw".
Marky82 is offline   Reply With Quote
Tags
tree stump removal
Remove Fence Post Involved with Tree kaehlin Landscaping & Lawn Care 9 07-08-2017 10:20 AM
My tree isn't looking so good. Pics inside Eds_tls Landscaping & Lawn Care 3 06-19-2013 03:35 AM
Handles For Tree Stump Seating KDogHall Building & Construction 18 04-05-2013 09:38 PM
maple tree stump grindings turning grass yellow johnnyboy Landscaping & Lawn Care 4 08-21-2009 03:22 AM
How to prevent tree stump from rotting? Jeremy Hillary Boob, PhD Landscaping & Lawn Care 8 06-21-2009 08:16 AM
