Recommendation On Hand Held Pump Sprayer - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Like Tree5Likes
  • 2 Post By Bondo
  • 1 Post By tstex
  • 1 Post By Canarywood1
  • 1 Post By RRH
Old 02-16-2019, 12:52 PM   #1
Rewards Points: 2,038
Recommendation on hand held pump sprayer
Hello to all,
I am seeking advice on what are the most reliable hand-held pump up sprayers [2 or 3 gal]. Looking for specific make and model?
No matter what brand I get, the handle starts to leak, the pump mechanism fails, etc. Note, I always clean up my units afterwards and lube O-Rings and other parts per instructions. And, I do not dispense products that destroy the unit.
I saw a review for the top 10 best HH pump sprayers, but the ratings were 3 stars, etc. I always seek the most critical reviews so I can see if the products fail, made bad, low quality or user error.
Thank you very much, tstex
tstex
tstex is offline   Reply With Quote
Old 02-16-2019, 01:02 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,642
Re: Recommendation on hand held pump sprayer
Went backpack.
This one has been good: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Old 02-16-2019, 01:02 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Ayuh,..... 'bout every pump sprayer I've ever seen on a jobsite over the last 30 years or so, has been a Chapin sprayer,......
Windows on Wash and Msradell like this.
Old 02-16-2019, 01:14 PM   #4
Windows and Bondo - these are great suggestions - thank you VERY much !!
Bondo likes this.
Old 02-16-2019, 06:22 PM   #5
Rewards Points: 1,042
Got this one as a gift, 3 year warranty comes with lithium ion battery and charger, works really well.
https://www.ryobitools.com/outdoor/p...emical-sprayer
joecaption likes this.
Canarywood1 is offline   Reply With Quote
Old 02-16-2019, 07:18 PM   #6
RRH
Rewards Points: 1,336
Yes, chapin will be the best you can buy. Not there very cheap ones made for the box stores.
Need one that says VITON seals. (Better rubber parts)
Retail on the good ones are high.
This is the cheapest you want to buy and a good deal.
https://www.amazon.com/Chapin-26021X...52371748&psc=1
Msradell likes this.
RRH is offline   Reply With Quote
Old 05-01-2019, 04:46 PM   #7
Rewards Points: 600
The Smith Contractor garden sprayers are very reliable and they have a separate pressure release valve. The release valve is a great alternative to trying to slowly remove the pump mechanism and not have chemicals sprayed into your face.
Different models have different seals depending on the chemicals used.
Calson is offline   Reply With Quote
Old 06-20-2019, 01:08 AM   #8
Rewards Points: 130
I've got a 3 gallon Solo sprayer that's lasted 6 years, so far. If it starts to leak, I just spray all the o-rings with silicone.
mrlabradog is offline   Reply With Quote
Old 06-20-2019, 06:33 AM   #9
ZTMAN's Avatar
Rewards Points: 342
I find it amusing that the Amazon vendor gives the option to buy one for $34.62, but a two pack for $96.30.?????
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 06-20-2019, 07:08 AM   #10
Thanks for your feedback guys - appreciate it
Old 06-20-2019, 10:32 AM   #11
Rewards Points: 600
I selected the Chapin battery powered backpack sprayer in part because the company provides excellent customer support for their sprayers which are less reliable than the simple pump sprayers.
What is important is the availability of spare or replacement parts for a sprayer like the hose and wand assembly and the seals. I have had to send sprayers off to the local landfill for want of replacement parts.
Old 06-20-2019, 12:25 PM   #12
DoomsDave's Avatar
Rewards Points: 5,682
I had one of those Spray Doc plastic tank sprayers since about 1986, and it still worked well, until I couldn't find parts to overhaul it with.
DoomsDave is offline   Reply With Quote
Old 06-20-2019, 01:18 PM   #13
Rewards Points: 528
I've had the same issue as the OP. Seems like they start leaking whatever you put in the tank all over your hand, or the tips are junk, or the hose is junk after only one summer.
taylorjm is offline   Reply With Quote
Old 07-02-2019, 05:29 PM   #14
Rewards Points: 6,185
I use Stihl sprayers. Very well made and last a long time as long as you clean them after use.
dalepres is offline   Reply With Quote
Old 07-02-2019, 06:04 PM   #15
Thanks folks - I see you can buy generic replacement parts if you pump container and pump handle are still good. Keep the O-rings and other lubricated w a good grade of silicone that is used for pool parts...
pump sprayer tramp Landscaping & Lawn Care 4 12-06-2018 09:11 AM
Septic Pump problem: continually tripping the breaker mammatus Electrical 7 01-16-2018 03:57 PM
Question about piping for a well pump ktkelly Plumbing 6 04-23-2015 11:23 PM
Recommendation on a good furniture grade sprayer + other questions..? noone Painting 0 02-13-2012 08:49 AM
Pump recommendation Ultrarunner2017 General DIY Discussions 10 08-31-2011 01:16 PM
