Question Regarding - Cinder Block Raised Garden Bed - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 02-15-2015, 06:35 PM   #1
Rewards Points: 54
Question
Hello everyone,
Previous I made a few raised beds out of pallet wood and then I used PVC pipes to make a lid frame with chicken coup wire that I attached using C clamps screwed into the wooden frame.
I notice the wood is begging to warp and crack... and I don't feel like screwing around with pallets again. So this time I would like to try making the raised beds out of cinder blocks. But I am having trouble deciding on how I would attach a PVC lid to the raised bed.
I am trying to keep the cost down as much as possible, and I know the blocks will cost me money, but I expect them to last for years to come.
Here is a picture of what I did before. All suggestions are welcome. Thanks!
Zyclone is offline   Reply With Quote
Old 02-16-2015, 07:42 AM   #2
Rewards Points: 6,989
You have several choices depending on the tools you own or can borrow.
Screws can be installed into block or concrete using plastic or lead anchors after drilling the correct size hole. Far faster is to use Tapcon screws which cut threads into the masonry after it i is drilled. The Tapcons are cheaper than the anchors and bit IMO.
Other options exist but these are the best two.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
The Following User Says Thank You to Colbyt For This Useful Post:
Zyclone (02-16-2015)
Help with a Fence to Cinder Block Wall avandelay Carpentry 7 08-30-2013 09:17 AM
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
Removing White Powdery Substance From Cinder Block Lawrence Coppar Concrete, Stone & Masonry 5 04-12-2012 02:28 PM
Cutting cinder block for a large door opening joeyb Building & Construction 2 02-10-2008 12:00 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
