Putting In Arborvitae's - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 05-03-2015, 05:31 PM   #1
Wench's Avatar
Rewards Points: 109
Putting in arborvitae's
We put 8 arborvitae's in along the fence line last year. We want to finish putting the rest in down the fence line. What's the best way to remove the existing grass/sod. We need to remove about 4 feet wide and 25 feet long, I'm not sure how my husband did it last year but he said it was a pain in the butt...is there an easy way to remove it?
Wench is offline   Reply With Quote
Old 05-03-2015, 07:33 PM   #2
Location: SE Michigan, zone 5/6 depending on winter intensity
Rewards Points: 72
I think there are probably better ways than what I do, which is to kill the grass by solarizing it. It still will have to be dug out, but it isn't as healthy once it starts dying.
Actually I think preparing the soil is a lot harder than clearing the grass because you really need to dig out an area larger and deeper than the root ball before you can plant. If you've got clay soil, back aches may be a side result of all that digging.
NorthernWinds is offline   Reply With Quote
Old 05-04-2015, 02:17 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 34
Just spay it with Roundup, no need to remove it all
The Following User Says Thank You to chrisn For This Useful Post:
oh'mike (05-04-2015)
Old 05-04-2015, 04:50 AM   #4
Retired Moderator
Rewards Points: 7,174
If you do choose to use a flat shovel to slice it out like sod----sharpen the shovel--use an angle grinder or a bench grinder---or even a file---you need that shovel to be sharp as a knife.
Old 05-04-2015, 09:04 PM   #5
Lord of Slums
Rewards Points: 1,974
I saw this sod cutter on youtube, guy pushed it like a lawn mower and it cut the grass off in strips.
mj12 is offline   Reply With Quote
The Following User Says Thank You to mj12 For This Useful Post:
Old 05-05-2015, 09:09 PM   #6
Rewards Points: 1,002
Best way is for your husband to get his Wench out there with a garden spade and cut some lines about a foot wide, then come back and take out the sod.
If you have some place that needs grass, you can transplant that sod and it will take off quite well. I cleared out a 12x18 area like this recently and it went well.
cleveman is offline   Reply With Quote
Old 05-06-2015, 12:32 PM   #7
Rewards Points: 72
Cleveman, good suggestion about using the sod elsewhere. Or it could be added to a compost pile as long as it hasn't been sprayed with toxic chemicals.
Washer not putting out cold water simplelife Appliances 9 07-27-2013 04:39 PM
Planting Emerald Green Arborvitaes zephed666 Landscaping & Lawn Care 2 04-19-2011 06:28 AM
Putting Window in Garage Wall palmernjp New Member Introductions 0 09-29-2009 04:18 PM
putting stone vaneer on painted cinder block dlmont75 Carpentry 2 06-28-2009 08:04 PM
putting up car shelter mudpaws Building & Construction 1 04-27-2009 10:32 PM
