Propagating A Split Leaf Philodendron? - Gardening Forum - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Like Tree6Likes
Old 05-28-2016, 09:05 PM   #16
r0ckstarr's Avatar
Rewards Points: 82
Re: Propagating a split leaf philodendron?
Originally Posted by Nik333 View Post
Sorry! Did it include a root when you pt it in?
That's why they died.
The only roots come out of the top and go into the ground. There were no small chutes of root nodes or anything like that.
I gave up on it for now and put my time back towards my Mexican Heather. I started with 12 of them 4yrs ago and am up to about 36 of them now.
Nik333 likes this.
r0ckstarr is offline   Reply With Quote
Old 05-28-2016, 09:19 PM   #17
Rewards Points: 4,226
Nice. I really like growing things. I was wondering if it would work to put the dip of a big plant stem, with aerial roots in a pot of earth, without cutting it. Then, if it grew new leaves you could cut it below or above the roots, or both. Hard to explain. :} There's a name for that technique, I will find it, for when you have everything else done!
r0ckstarr likes this.
Nik333 is online now   Reply With Quote
Old 05-28-2016, 09:39 PM   #18
r0ckstarr's Avatar
Rewards Points: 82
Me too. I'll have to post some pics up from my back yard plants.
Nik333 likes this.
Old 05-28-2016, 09:44 PM   #19
You have a similar USDA zone to me, but probably more humid, & more water.
I think I said before that there are lots of them in So. Calif., by the ocean.
Only roses, almonds, walnuts, olives, pistachios & oaks grow here. Yes, to Mexican Heather, though.
The Following User Says Thank You to Nik333 For This Useful Post:
r0ckstarr (05-28-2016)
Old 05-29-2016, 03:49 PM   #20
Apparently, the terms are Simple Layering & Air Layering. Scroll down.
http://www.planetnatural.com/plant-propagation/
r0ckstarr (05-29-2016)
Old 05-31-2016, 12:34 AM   #21
r0ckstarr's Avatar
Rewards Points: 82
Ok. I somewhat understand how to do that. When I was growing sweet potatoes, I noticed that for every 6-10 inches that the vine touched dirt, it would send roots down.
Nik333 likes this.
Old 09-10-2016, 07:22 AM   #22
r0ckstarr's Avatar
Rewards Points: 82
To update this. The plant was leaning over and completely blocking the walkway. I decided to cut it down at ground level. I covered the stump with a little bit of dirt, and it started growing back. I'm good with that, as it's like a whole new, much smaller, plant.
Nik333 likes this.
The Following User Says Thank You to r0ckstarr For This Useful Post:
Nik333 (09-10-2016)
Old 09-10-2016, 05:01 PM   #23
Smaller for now!
http://www.exoticrainforest.com/Phil...idum%20pc.html
r0ckstarr (12-16-2016)
Sources of Lead in Well Water xquercus Plumbing 3 09-01-2012 04:33 PM
Asbestos in lead & oakum bell joint? george.cox Plumbing 12 05-27-2012 11:12 PM
Should I reuse old trim that has lead paint? RenewATL Painting 1 05-27-2012 07:56 PM
Removal and disposal of lead shower pan gbook2 Plumbing 6 03-18-2012 09:33 AM
Replacing lead toilet drain and flange klondiker Plumbing 7 02-17-2012 09:53 PM
