Perimeter Around The House. - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 11-24-2014, 09:55 AM   #1
Rewards Points: 90
Perimeter around the house.
I would like to make a perimeter around the house where I can put chemicals and repellents for bugs. I was thinking of getting garden edge and putting it around the house (12") and filling it with P gravel. Was thinking of digging about 8" deep.
What do you guys think?
jesusq is offline   Reply With Quote
Old 11-24-2014, 09:01 PM   #2
Rewards Points: 996
if you want to do that, because it looks nice, then go for it.
if you feel you need a bug killer area, i doubt it. perhaps some killers also kill plants, idk of any.
Fix'n it is offline   Reply With Quote
Old 11-25-2014, 07:28 AM   #3
Rewards Points: 202
You want water to run away from your house. Don't know what your specific situation is, but if you have a lot of bugs against the foundation, it could be because the ground is wet, and I doubt that gravel is going to help that. Take a look at your grade, but typically you want something in the range of 1/8" to 1/4" of fall per foot, something like at least 6' or so out from your home. If you don't have that, a better solution may to bring it up to something like this, using dirt, so that a significant portion of water will run away from the foundation, rather than being held in low spots or gravel.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Attach ledger to vinyl sided house JamyTheBuilder Building & Construction 3 03-14-2012 02:54 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 08:58 PM
