Perennial Plant Recommendation - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 09-11-2015, 01:58 PM   #1
Rewards Points: 2,038
perennial plant recommendation
Hello to All,
Looking to replace some holly ferns that burned-up in the Hou summer heat and direct sunlight.
Receives sun from early morning to about 2-230pm, then shaded from fence. Has irrigation system. Soil is clay, but conditioned and continuing to amend w organics.
Looking for a recommendation on 1 gal perennials that can w stand heat but keep a low profile in height and expansion. Also desire color as well.
Any and all recommendations would be appreciated...if you have ques, fire away.
regards,
tstex
tstex is offline   Reply With Quote
Old 09-11-2015, 02:10 PM   #2
Rewards Points: 5,348
I like Phlox as it stays in one place, blooms from May to Frost and is about 24-30 " high. You'd need to check if it would flourish in your region.
Very few of my perennials bloom through out the season. I just plant things with a stutter step blooming sequence.
Right now it's the Shasta daisy's, Black eyed Susan's, Asters, mums and crape myrtles. An the phloxes.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
tstex (09-14-2015)
Old 09-14-2015, 09:10 AM   #3
Thanks Ron - how do these do in the heat? We can get up to 100-108 in summer.
regards,
tstex
Old 09-14-2015, 09:46 AM   #4
regards,
tstex
You local garden centers will be a good source. If you see them sold in your area, they should do okay.
Ron
B. Franklin 1759
Old 09-14-2015, 10:22 AM   #5
Rewards Points: 1,480
Check with local nurseries for a few of the many different cultivars of Euonymus Japonica that may satisfy your landscape.
Old 09-14-2015, 10:24 AM   #6
Thank you gentlemen
Old 09-15-2015, 08:04 PM   #7
Location: SE Michigan, zone 5/6 depending on winter intensity
Rewards Points: 72
There are a couple new hybrids that might fit your needs.
Bronze Age Yucca turns from green to lilac/violet/purple as temps drop. It's 1 -2' tall and wide., hardy in zones 5 to 9. So it should be able to tolerate Houston's 8b (according to the agricultural zone index) zone.
Silver Hedgehog holly is a holly with yellow, is hard in zones 6 to 9, but it can grow up to 20' tall and 12' wide, although generally shrubs can be pruned to keep them in shape.
Both are dramatic looking plants.
You could also try to deflect some of the sun in that area by planting taller plants in back of the smaller ones, but that would best if that side of the yard faces the south.
Phlox blooms about a month in my zone 5 - 6, and is quite lovely; wild phlox is especially pretty. It can grow into a mass, and can reach heights of 2 - 3 feet, depending on soil and water conditions.
Given that you're in a very hot area, you might want to look at some of the succulents as they hold water better than other perennials.
You could also try to deflect or block some of the hot sun by planting taller perennials or shrubs in back of the smaller plants, but that would work best if that side of the yard faces south.
NorthernWinds is offline   Reply With Quote
Old 10-04-2015, 03:10 PM   #8
Thanks N Winds...I have a few more plants I need and some of your recommendations might wk. I selected the Stella Del Oro Day lily for the sm plant and dwaft blush-pink Nandina for the larger of the two. It's really a reddish pink in color...We havethe soft-tip yucca in our portfolio now. The phlox seems to be a real winner around here too. Our 4 Bird of Paradise plants are getting ready to bloom...have about 2-3 blooms on 3 of them and 1-2 on another...w this cooler weather, maybe they'll last longer than 1 day.
Thanks again to all, tstex
Need help identifying and rescuing a very distressed plant miamicuse Landscaping & Lawn Care 8 02-11-2014 10:23 AM
Fall - A Great Time to Plant user1007 Landscaping & Lawn Care 1 08-27-2013 12:47 PM
White clover - annual or perennial ? Girly_girl Landscaping & Lawn Care 0 09-21-2011 05:35 PM
Need super heavy duty Plant poison. Help. gante Landscaping & Lawn Care 8 09-01-2009 12:05 PM
how would I go about propagating this plant? joeyboy Landscaping & Lawn Care 4 11-22-2008 07:33 PM
