Irrigation Controllers - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 07-27-2015, 12:08 PM   #1
Rewards Points: 2,038
Irrigation controllers
Hello to all,
We had a yr long project down in our back yard [pool & summer kitchen]. The old irrigation system lines were severed in many places, then new PVC, wiring and control valves were installed in the back to accommodate the new landscaping and grass.
We went from 8 active zones to 6 zones. We have a RainBird Controller that was installed new w house around 2004-2005. Well, it's been acting funny and something is wrong w it. Therefore, I need to replace it. Do not need anything real fancy, but was wanting suggestions on a controller replacement? I am assuming that the controller valves in the yard can use/read the software of any device, or should I stay w RainBird regardless.
Finally, this is just a matter of taking off the wires of the old controller to the same lines on the new controller so the zones will be consistent and labeled properly, correct?
Anything else, pls let me know?
Thank you very much,
tstex
tstex is offline   Reply With Quote
Old 07-27-2015, 02:12 PM   #2
Rewards Points: 190
Rainbird makes great controllers. They can be more expensive but you get what you pay for.
Look online for the manuals to verify the controller you are interested in had the number of zones and programs you need.
Controllers are pretty universal. The just complete a 24 volt circuit to open the valve.
It is a simple changeover of wires from old to new. Take a photo before you start. There will be a common wire (c) that you don't want to mix up. Label it before you start.
You can rearrange the wires for each zone into an order that makes sense to you.
Dan
djlandkpl is offline   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
tstex (07-27-2015)
Old 07-27-2015, 02:34 PM   #3
Thank you Dan. I appreciate your follow-up, especially the part on the common wire.
We only use 6 zones, but I think most come now w 8-10+, and most of the features regarding start times, watering times, etc should be pretty universal.
I get this done and post back on the results.
Thanks again,
tstex
Old 07-27-2015, 02:50 PM   #4
How does this RainBird model look?
http://www.zoro.com/rain-bird-irriga...g&gclsrc=aw.ds
Old 07-27-2015, 02:56 PM   #5
Rewards Points: 190
Originally Posted by tstex View Post
Looks good. Simple to use and room for growth.
Dan
Old 07-27-2015, 03:25 PM   #6
I found out that you cannot initiate a "manual cycle" w a one-key-touch so I am back to the drawing board.
Old 07-27-2015, 03:30 PM   #7
Rewards Points: 190
Take a look at the Rainbird site but follow the Professional links. The controllers have more functionality.
Dan
Old 07-27-2015, 04:17 PM   #8
Thanks. I looked at them but a lot of the are 4-22 zone systems and way overkill.
This one looks good: Rain Bird RZX8I Eight Station ESP-RZX Indoor Sprinkler Timer
Thanks,
tstex
The Following User Says Thank You to tstex For This Useful Post:
djlandkpl (07-27-2015)
Old 08-05-2015, 09:50 AM   #9
I bought an Orbit 12 zone w remote control. I was able to program it in about 10 min's. It worked correctly the first night and has since then.
When installing one brand to another, [rainbird to orbit], make sure you look at the distance you need to the wires to connect to each station. The rainbird needed less, so I had to cut off some of the top of the PVC pipe feeding the wires.
Next, make sure you clearly label all of your station wires. this will ensure you don't have to do a lot of testing and switching later.
Haven't used the remote yet, but it should be real handy instead of running from controller to s-heads....regrds, tstex
djlandkpl (08-05-2015)
strange noise under house when irrigation system shuts off eitnum General DIY Discussions 7 08-16-2014 02:26 PM
Running two lines off one irrigation pump? bassadict69 Landscaping & Lawn Care 3 04-14-2014 01:55 PM
Irrigation System Supply exiting through House? Ocelaris Landscaping & Lawn Care 2 03-29-2013 10:04 PM
Pressure Reducing valve and location irrigation branch line ironqqq Plumbing 3 07-14-2012 01:53 PM
Replacing old galv irrigation pipe tns1 Plumbing 8 09-11-2010 04:08 PM
