Identify This Grass: POA Annua Or Blue Grass - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 04-22-2019, 01:31 PM   #1
Rewards Points: 132
Identify this grass: POA annua or blue grass
Hi
Is this poa annua or Kentucky blue grass?
Identify this grass: POA annua or blue grass-img_8595.jpg
Closer look...
Identify this grass: POA annua or blue grass-img_8594.jpg
Thanks.
007noob is online now   Reply With Quote
Old 04-22-2019, 06:01 PM   #2
Rewards Points: 4,864
Re: Identify this grass: POA annua or blue grass
Never seen bluegrass grow in a clump like that. No idea what the other option is you mention.
stick\shift is offline   Reply With Quote
Old 04-22-2019, 07:34 PM   #3
DoomsDave's Avatar
Rewards Points: 926
@007noob , I think that is Poa annua, annual bluegrass, which means, after one season, ACK! dead. Not a good lawn grass for the long term but has its uses.
DoomsDave is online now   Reply With Quote
Old 04-22-2019, 08:11 PM   #4
Rewards Points: 132
Would Spectracide weed stop do away with POA or do I need something else?
Thatís what I usually use for other weeds.
Old 04-22-2019, 08:40 PM   #5
DoomsDave's Avatar
Rewards Points: 926
Weeders with glyphosate (like Roundup, et al) will kill actively growing plants. But it will not take care of seeds, and if the grass has been there a while, you may have some.
What's your plans for the place?
Old 04-23-2019, 09:57 AM   #6
Rewards Points: 132
The plan for this section of area is to get rid of the unwanted vegetation and cover with pine bark mulch. I have a row of small Blue Point Junipers that was planted last year. I would like to get rid of the weeds without harming the small Junipers.
Old 04-23-2019, 12:51 PM   #7
DoomsDave's Avatar
Rewards Points: 926
Okay, that sounds relatively easy to do, compared to putting in a new section of lawn.
I'd pull out all the weeds, and put down the mulch, and be prepared for further weed removal. You can also use "weed mat" which is meant to stop weeds, while still allowing water to get to the soil; you put it on the surface, the put the mulch on top of the mat. The problem with weed mat is that, after a while, weeds begin to grow on top of it, though they're a lot easier to remove.
If you use weedkillers, junipers aren't harmed much by those, though I'd try to be as sparing as possible. They aren't as sensitive as non-woody non-coniferous plants.
Kentucky blue grass new sod dead or dormant? mxkjk2 Landscaping & Lawn Care 7 07-11-2017 12:34 PM
How to identify lawn grass types findlay70 Landscaping & Lawn Care 1 07-06-2010 08:10 PM
Can anyone identify this grass? joshoc Landscaping & Lawn Care 6 06-22-2010 03:47 PM
Smoke or steam coming from grass Holt Landscaping & Lawn Care 0 11-05-2009 10:53 AM
Swapping grass varieties... opinions? joeyboy Landscaping & Lawn Care 5 03-11-2008 08:06 PM
