How Can I Get Rid Of Tree "shoots"? - Gardening Forum - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Like Tree7Likes
Old 08-19-2018, 07:18 AM   #16
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,340
Re: How can I get rid of tree "shoots"?
Originally Posted by CaptTom View Post
Moxie beat me to it. If you just keep mowing, eventually you'll starve out whatever life is left in the roots.
Very cool though, I've never seen such an aggressive tree! Usually I see shoots come up from the old trunk, never the whole root system.
Hey, Moxie, what's this crap about your location being in NY? I thought you were a Mainer! You know what we think of NY'ers here, right??
Ayuh,..... Born, 'n raised in Old Town,.....
Maineiacs, like the rest of the planet don't realize there's a Huge state here, that isn't NYC,.....
'ell,.... where I'm at now, is more desolate than Old Town,.....
Back when I was travelin' the country in my 18-wheeler, I never admitted to livin' in NY, 'n always said I'm a Maineiac,.....
CaptTom likes this.
Old 08-19-2018, 07:35 AM   #17
gloriousglenn's Avatar
Rewards Points: 43
Well, that is certainly the easiest and cheapest option.
I'm guessing once the winter is here and that grass is under a few feet of snow, that that'll help too?!
gloriousglenn is offline   Reply With Quote
Old 08-19-2018, 08:58 PM   #18
Rewards Points: 576
The suckers showed up in ONE WEEK.......Egads. My guess is that there were a lot of surface roots many feet away from the stump...and some how they were nicked, mowed, tilled or otherwise disturbed...and as a result, many suckers emerged. Sound possible ?
Cedrus is offline   Reply With Quote
Old 09-21-2018, 05:55 AM   #19
Rewards Points: 14
A pair of hand pruners would be the best option to remove the tree shoots. Cut the tree sprouts as low as you can. You can also use sucker control products to get rid of the tree shoots. But you should use the sucker control products carefully as overuse can harm your tree/plant.
emmacornette1 is offline   Reply With Quote
Old 12-07-2018, 07:09 AM   #20
DoomsDave's Avatar
Rewards Points: 5,520
For what it's worth, you're not alone!
I took out a Brazilian Pepper tree here in California, and it did the same thing. Over the years it had also sent up shoots before I cut it down. It had also send out new shoots, though not as many as on your silver maple.
I applied glyphosate straight on as many of the shoots as I could. The softer greener ones died more quickly.
In your case, given the number of soft green shoots, I'd try putting a few drops of straight glyphosate (Roundup, KLeenup, etc) on as many of the shoots as possible. That should cut down the number of them. Then, keep dosing the remainder till they're all gone. I'd do my best to get them all; don't leave any. It'd also paint the stump with straight glyphosate or "Brush B Gone" which contains tricofyr.
Be patient, and persistent.
If you hate chemicals, you might want to try repeated repeated close mowings, too, thought that can take a while, possibly a long while.
DoomsDave is online now   Reply With Quote
Old 12-07-2018, 07:54 AM   #21
Bondo's Avatar
Ayuh,.... So, how often do you mow yer lawn,..?? weekly,..?? Bi-weekly,..??
Just keep mowin',.....
What yer seein' is the tree's last grasps at life,.....
It'll die out after awhile,.....
Then the old roots will rot, causin' ruts in the lawn, you'll have to fill in,....
Old 12-07-2018, 09:39 AM   #22
DoomsDave's Avatar
That does work, sometimes.
Other times, you literally end up with a lawn of little bitty tree sprouts that, like zombies, refuse to die.
Old 12-07-2018, 10:24 PM   #23
Rewards Points: 894
We used Crossbow and it seems to have killed the elm and the shoots. But, snow is covering the ground now. Would someone write this down in the March calendar?
DoomsDave likes this.
fireguy is offline   Reply With Quote
Old 12-10-2018, 01:45 PM   #24
DoomsDave's Avatar
Thanks for the tip!
Crossbow might be a bit cheaper than Brush B Gon; both contain tricofyr.
Be warned, though that some plants are very hard to kill with weed killers, like Eucalyptus.
Guide to cut down a tree Michae888 Flooring 2 09-01-2017 09:46 AM
Help Me Save a Tree! l008com Landscaping & Lawn Care 11 06-30-2017 10:35 PM
Extending deck around a tree jcgoldie Building & Construction 2 02-15-2011 05:20 PM
