Has Anyone Used This Grass Seed (Water Saver)? - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Like Tree1Likes
Old 08-28-2019, 09:23 AM   #1
VAer's Avatar
Rewards Points: 1,562
Has anyone used this grass seed (Water Saver)?
What air temperature for planting this grass seed? Is it okay for DC metro area? Can it be used for over seeding? How many days will it likely take to sprout?
Is it really drought tolerate and self-repairing?
Thanks.
Product link: https://www.homedepot.com/p/Water-Sa...1625/203226761
VAer is offline   Reply With Quote
Old 08-28-2019, 10:03 AM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,192
Re: Has anyone used this grass seed (Water Saver)?
Like miloganite it's meant for inopportune applications - like when it's too hot.
Both being an extra and un-neccesary expense when dropped
(seeding or fertilizing) at the correct times such as fall and spring.
But the package has some cool graphics.
Old 08-28-2019, 12:08 PM   #3
Rewards Points: 6,997
Fescue has deeper roots than bluegrass or many other lawn grasses. That price is about double what I pay for 25 pounds of fescue so you may be able to do better elsewhere.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 08-28-2019, 12:22 PM   #4
Rewards Points: 7,518
What kind of grass do you have now?
If you have Kentucky bluegrass now, I would consider tall fescue a weed. I put Roundup on it when I see it.
SPS-1 is offline   Reply With Quote
Old 08-28-2019, 12:27 PM   #5
VAer's Avatar
Two years ago, contractor told me it is Tall Fescue, but not sure which brand of Tall Fescue. But I don't think it matters, as long as it is Tall Fescue.
Tall Fescue cannot self repair, but this one seems to be able to self repair.
Old 08-28-2019, 12:30 PM   #6
VAer's Avatar
I have tried other brands during past 2-3 years, they don't end up well. Every summer, crabgrass takes over some spot, and I keep over seeding every year.
If this grass seed can provide thick lawn to prevent weed out, it is worth the money.
Old 08-28-2019, 12:39 PM   #7
VAer's Avatar
The primary reason for me to consider it: Self-repairing. Every year, some grass die due to crabgrass takes over or drought
The second reason is: tolerate drought. Often forget(also busy) to water the lawn when it is over 90F.
I am tired of over seeding almost every year. Repair the lawn and become a little better, then some grass die again in summer, the repair again in the fall, ....
So I hope I can find something can REALLY self repair. Since I have not tried this grass seed, not sure if it works as stated.
Old 08-28-2019, 01:00 PM   #8
MarginallyQualified
Every year, some grass die due to crabgrass takes over or drought...
The grass seed won't fix these issues.
The drought protection is at seeding time... not forever.
Old 08-28-2019, 01:14 PM   #9
Crabgrass will die off with the first freeze, but by then it has already dropped it's seeds, and they will start coming up later next spring.
Pull the crabgrass as soon as you see it, and then in the spring, put down a pre-emergent fertilizer that will keep the crab crass seeds from germinating. Pre-emergent will also keep any other type of seed (i.e grass) from germinating, so fall would be the time to do any over-seeding. Not sure how much crabgrass you have, but could take a few years of the above procedure to totally eliminate it. And if you don't take care of your crass, you are just inviting more crabgrass and other weeds.
Old 08-29-2019, 12:27 AM   #10
Rewards Points: 4,170
Then tall fescue is a poor choice for your lawn. I would suggest looking into replacing with zoysia - it will be brown a little earlier in the fall and later in the spring than tall fescue but it self repairs and handles the heat of summer much better.
stick\shift is offline   Reply With Quote
Old 08-29-2019, 09:55 AM   #11
They are spreading fescues but I don't think there is a tall one that is spreading.
Colbyt
Old 08-29-2019, 12:39 PM   #12
DoomsDave's Avatar
Rewards Points: 5,532
Sounds like you have K-31, which looks like a weed. Marathon II looks almost like KBG.
DoomsDave is offline   Reply With Quote
Old 08-29-2019, 12:46 PM   #13
VAer's Avatar
What do you mean? It says "tall fescue" on the bag?
Can I use this grass seed alone? Or do I need to mix it with other tall fescue grass seed?
Old 08-29-2019, 12:57 PM   #14
More precisely, it says rhizomatous tall fescue, which is a variety that can spread (supposedly) by rhizomes underground, not just seed.
Old 08-29-2019, 12:59 PM   #15
VAer's Avatar
So it is seed with RTF, and I do NOT need other grass seed for over seeding anymore?
It is the product I can use alone, without mixing with other grass seed?
