Framing A Herb Planter With PT Lumber - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 02-23-2017, 05:42 PM   #1
Rewards Points: 2,412
Framing a herb planter with PT lumber
I am planning on building a rectangular wood frame consisting of pressure treated 4X4 lumber.
The frame will then be filled with top soil for planting herbs.
One concern is whether it is safe to consume plants grown near pressure treated lumber.
My search turned up many articles and warnings about toxins leaching out from PT lumber.
and just as many articles saying the opposite, that the new pressure treated wood produced today contains nothing that is harmful.
Thoughts and comments? Safe to use?
miamicuse is online now   Reply With Quote
Old 02-23-2017, 05:56 PM   #2
Rewards Points: 17,912
Re: Framing a herb planter with PT lumber
Total non issue!!!
New pressure treated wood is treated with copper not arsenic.
I make all of mine with 6 X 6's not 4 X 4's for several reasons.
Far less likely to twist, curl, more depth for the good stuff.
I back fill mine with compost, not top soil.
Far more of the needed nutrients.
Old 02-23-2017, 08:18 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 2,160
I agree with Joe but I'll bet there is a site out there extolling the evils of leached copper. If it helps you sleep at night, you could line sides of the box with heavy plastic or cedar.
lenaitch is offline   Reply With Quote
Old 02-23-2017, 10:31 PM   #4
JUSTA MEMBER
Rewards Points: 4,004
And the answer is:
Read this.
http://ccs.infospace.com/ClickHandle...cop=main-title
ED
de-nagorg is online now   Reply With Quote
Old 03-14-2017, 02:57 PM   #5
Flannel Guy DIY
Flannel Guy DIY's Avatar
Rewards Points: 224
be careful using PT lumber
Flannel Guy DIY is offline   Reply With Quote
Efficient framing and framing lumber Geran Brown Building & Construction 13 11-17-2013 01:24 PM
pocket hole jointery and cabinet screws for framing newbymodeler Carpentry 29 03-07-2013 03:17 PM
Framing Treated Lumber Sbagwell647 Building & Construction 7 07-14-2011 11:04 PM
Double Framing on old Garage? bofusmosby Building & Construction 6 04-12-2010 09:08 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
