Filling Depressions In The Lawn - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 05-19-2019, 07:07 PM   #1
Rewards Points: 78
Filling depressions in the lawn
I’ve got some lawn depressions from trees that were cut out years ago. I want to try to level these and have read that one way to do it is just fill them with dirt and the grass should grow through it. I’m kinda lazy and old, so feel this is the method for me. If I do this, does it matter what kind of dirt/soil to use? My so head some organic garden soil left over and said I could have it. Would that do, or should I use something else?
TonyMan is offline   Reply With Quote
Old 05-19-2019, 07:38 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 2,228
Re: Filling depressions in the lawn
I'd just buy some topsoil, lightly tamp it level and rake in some seed. If you later find it's still not completely level you could top dress it again a likely not need more seed. Topsoil is a mix of organic material with non-organic material - sand and clay. I would worry that pure organic garden soil is too rich and may break down over time.
_________________________________________
Who Dares Wins
lenaitch is offline   Reply With Quote
Old 05-19-2019, 08:06 PM   #3
dd57chevy's Avatar
Rewards Points: 2,732
Not sure what you mean by "organic garden soil". If you mean compost or composted manure , you'd want to dilute it , maybe 4 parts regular topsoil (AKA DIRT ) to 1 part compost .
If you mean the bagged potting soil , it will grow the daintiest flowers & should be ok for grass .
dd57chevy is offline   Reply With Quote
Old 05-19-2019, 09:47 PM   #4
Rewards Points: 4,192
Grass will only grow through about and eight to quarter inch of dirt so plan to seed.
stick\shift is offline   Reply With Quote
Old 05-19-2019, 10:10 PM   #5
Rewards Points: 78
Thanks folks, appreciate it.
Old 05-20-2019, 06:14 AM   #6
retired painter
Rewards Points: 1,868
Ideally you'd cut out the sod, add soil and then replace the sod but as I get older I understand the value of taking the easy route. If going that way I'd either slowly add soil over time or level it off and seed.
mark sr is offline   Reply With Quote
Old 05-20-2019, 09:08 AM   #7
Rewards Points: 524
Yes, use a good top soil to get the area close to level. Once you rake it over after tamping, sow grass seed. Once the grass has grown, use sand to level out everything. I have started raking in sand over the entire yard and raking it in. That levels all ground perfectly. It will take approx 3 years to complete to have nice, smooth ground over the entire yard. My yard takes approx 75 tons of sand. I have it delivered and dumped all around in certain areas. Then I use a small wagon to be pulled behind a mower. I then use a rake of a thing that I built. I pull that behind the mower also. It works to rake in all the sand to some what level. Normal gravity, time and rain make it perfectly smooth and level. Golf courses use a very expensive pieces of equipment to preform this task. But that is how they get putting greens smooth and level.
Andrew
Handy Andy In Mt Airy NC
HandyAndyInNC is offline   Reply With Quote
Old 05-20-2019, 11:16 AM   #8
Dave Sal's Avatar
Rewards Points: 1,210
Originally Posted by TonyMan View Post
Iíve got some lawn depressions from trees that were cut out years ago. I want to try to level these and have read that one way to do it is just fill them with dirt and the grass should grow through it. Iím kinda lazy and old, so feel this is the method for me. If I do this, does it matter what kind of dirt/soil to use? My so head some organic garden soil left over and said I could have it. Would that do, or should I use something else?
I have the same issue also caused by cutting a large tree last summer. I filled in the holes last year with top soil and grass seed but that didn't seem to work out very well. I still have the depressions in the lawn and have decided to get more top soil, fill the holes, tamp it down, and then put pieces of sod on top. I'm pretty sure that will fix the problem for good.
Dave Sal is online now   Reply With Quote
Old 05-23-2019, 02:26 PM   #9
Rewards Points: 88
Would sand have weeds in it like some topsoil has?
diy_jeff is offline   Reply With Quote
Back filling and grading lawn HDS Landscaping & Lawn Care 9 04-04-2016 11:13 AM
Back filling a hole in lawn Master Brian Landscaping & Lawn Care 2 06-22-2013 11:47 AM
What the hell happened to my lawn? (also: reseeding when weeds are present. N.Y.) Deck Landscaping & Lawn Care 14 05-24-2011 12:45 PM
Trying to revive dead lawn... deevahs Landscaping & Lawn Care 2 05-13-2010 12:34 PM
Need advice for filling in bare spots in new lawn golfer2b Landscaping & Lawn Care 1 05-01-2009 06:44 AM
