Dehydrating Hot Peppers - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Like Tree4Likes
  • 1 Post By Colbyt
  • 1 Post By rjniles
  • 1 Post By raylo32
  • 1 Post By Two Knots
Old 08-13-2019, 09:43 AM   #1
raylo32's Avatar
Rewards Points: 900
dehydrating hot peppers
Looks like I am getting a bumper crop of ghost peppers (bhut jolokia), far too many to use in real time since they are sooooo hot. I have tried to dehydrate these a couple times in the past and had no luck. I tried low temps in a toaster oven, and simple air dehydrating. Different but bad results each way. Anyone here know a reliable DIY way to do this or do you really need a real dehydrator?
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 08-13-2019, 10:36 AM   #2
Rewards Points: 6,981
Re: dehydrating hot peppers
Any pepper is one of the harder things to dehydrate. I suggest freezing them in single use size baggies. They will be fine for cooking when thawed. I have tried blanching and raw freezing with cores removed and can tell no difference between the 2.
DoomsDave likes this.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
Old 08-13-2019, 11:52 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 636
My wife grows and dried mini peppers. Sews them on a string and hangs in a sunny window.
Sent from my Moto E (4) Plus using Tapatalk
Nik333 likes this.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 08-13-2019, 05:28 PM   #4
david86camaro's Avatar
Rewards Points: 4
I have dehydrated peppers many times before (not ghost peppers, but other hot peppers) with a dehydrator, but out in the garage otherwise you will not be able to be in the house, it fills the air with the “heat” of the peppers.
david86camaro is online now   Reply With Quote
Old 08-13-2019, 08:52 PM   #5
Rewards Points: 4,198
What went wrong?
Btw, how are your tomato plants?
Nik333 is online now   Reply With Quote
Old 08-14-2019, 04:53 AM   #6
Naildriver
chandler48's Avatar
Rewards Points: 4,148
I freeze much of the peppers and spices we grow. BUT I use a sealing machine that sucks out all the air. They keep a lot longer without the condensation that often results in freezer burn. As Colbyt says, small bags at a time.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 08-14-2019, 05:16 AM   #7
Rewards Points: 251
This. I buy bell peppers in different colors - clean, chop into pieces then placed in freezer in separate baggies. I don’t even blanch or vacuum seal them. Makes it so convenient to just grab a handful to toss into stews. I don’t know if they’re any good (crisp) in a raw salad mix.
I do the same for tomatoes and ginger. Frozen ginger is fun to grate.
Druidia is offline   Reply With Quote
Old 08-14-2019, 05:55 AM   #8
raylo32's Avatar
Rewards Points: 900
On my previous attempts the peppers ended up rotting before they got dry. Tomatoes are mostly doing well. The Roma plants are making lots of fruit, although the variety I got doesn't have a lot of pulp inside. But they make good tomato sauce.
I did freeze a batch last year and they kept OK. I just froze them whole in double freezer bags. I take out one at a time for use. I still have some of last years in the freezer that I will toss and replace.
Originally Posted by Nik333 View Post
What went wrong?
Nik333 likes this.
Old 08-15-2019, 08:18 AM   #9
DoomsDave's Avatar
Rewards Points: 5,486
Hmm. @raylo32 :
I've dried Japapenos and tomatoes by putting them on cookie sheets in the hot sun, and putting screen over them to keep bugs out.
Keep in mind, it's a lot dryer here than in MD, though.
I also have used @rjniles ' wife's approach as well, though it seems to work best with small peppers.
And, do please mind @david86camaro 's warning! Pepper "hot" is an oil and it gets all over. It will clear your sinuses, ho-ho-ho yeah, sometimes more than you bargain for.
Be especially mindful of ghost peppers with, what, something like a million Scovill units apiece.
I suspect you already know all that, I'm just giving a public service warning. (I've gotten a few of those here!)
DoomsDave is online now   Reply With Quote
Old 08-15-2019, 08:22 AM   #10
DoomsDave's Avatar
Ever try drying them in the hot blistering sun?
Old 08-15-2019, 10:22 AM   #11
This KY. The bugs and humidity would cause rot before they dried. As a boy I recall neighbors stringing up and air drying small, ripe peppers for winter use but I've not done it. Freezing works well for me.
Colbyt
Old 08-15-2019, 10:40 AM   #12
Two Knots's Avatar
Rewards Points: 4,153
I string up my italian long hot peppers with a needle and thread through the stem.
Then I just string up the whole thing and hang them up
somewhere (not in the sun)
When they’re totally dried out I fry them quickly in hot olive oil
turning frequently ( It only takes a minute) They blow up and get
crunchy remove them to a plate and immediately salt them.
very delicious crumbled over pasta and lots of other dishes.
Nik333 likes this.
Behind every clever man is an astonished woman!
*Joann*
Dogs love me, men fear me!
Two Knots is offline   Reply With Quote
Old 08-15-2019, 01:41 PM   #13
I found this from a more humid area. https://extension.umn.edu/preserving...ying-food-home
I wonder if slicing them would increase the success of drying? I know it takes away from the beauty, but, it might mean success. Just wear gloves or don't touch your face, eyes!
They recommend where I live to dry peppers or Arizona.
