Can I Lay A Thin Strip Using Sod? - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Like Tree1Likes
  • 1 Post By SPS-1
Old 07-27-2019, 05:34 PM   #1
Rewards Points: 52
Can I Lay a Thin Strip Using Sod?
All around my lawn the edges have gotten too wide (for a variety of reasons I wonít bore you with.) So my goal is to add about 2 inches of grass to almost the entire edging of my lawn. The question is how? I am debating seeding vs. sod.
I can easily get a few rolls of sod and cut 2-inch strips to fix the problem but itís been suggested that sod be cut no smaller than 6 inches wide for successful growth. Is that true? I can also remove about 4 inches of good lawn and then roll in 6-inch strips Ė but that means removing lots of good grass, and if it should fail to catch, Iíve ruined a very visible part of my lawn!
Seeding will take longer to grow but may make more sense. Either way, watering twice a day is gonna be very time consuming because of the amount of lineage to cover. I plan on undertaking this mid-September when it starts to get cool. Rainy days will aid with the watering.
Looking for suggestions to do it right. Specifically, has anyone successfully laid sod in such a small width? Thanks in advance
Steveromo is offline   Reply With Quote
Old 07-27-2019, 05:38 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 23,738
Re: Can I Lay a Thin Strip Using Sod?
If you keep it watered it should be fine.
I have often trimmed strips off the edge of my sidewalk that 2 inches or less and used them successfully as sod.
Old 07-27-2019, 05:58 PM   #3
retired framer
Rewards Points: 20,270
For the cost of a bit of grass, it is well worth the try.
Do not use flat bottom gables with scissor trusses.
Old 07-27-2019, 06:21 PM   #4
Rewards Points: 7,506
I have put down sod a number of times. Never 2" strips, but for sure the edges have the greatest risk, so I can believe the advice that 6" strips is safer than 2" strips.
Trouble with seed is that its a lot of time to keep it moist, and then a bunch of weeds are going to come up with the grass.
SPS-1 is online now   Reply With Quote
Old 07-27-2019, 06:25 PM   #5
Rewards Points: 1,042
Those same weeds will come up with sod also.
Canarywood1 is offline   Reply With Quote
Old 07-27-2019, 06:55 PM   #6
No they don't.
Msradell likes this.
Old 07-28-2019, 09:02 AM   #7
Rewards Points: 52
Thanks for the replies and advice! Will follow up later in Fall with the results
Old 07-28-2019, 02:21 PM   #8
Rewards Points: 576
Get the thickest sod you can....1-2 inch. Cut it to 3 inches wide and cram it in tightly.
Cedrus is offline   Reply With Quote
Old 07-28-2019, 10:20 PM   #9
DoomsDave's Avatar
Rewards Points: 5,522
@steveromo mo, what kind of grass?
If Kentucky Blue, keep moist.
DoomsDave is online now   Reply With Quote
Old 07-29-2019, 07:57 AM   #10
Rewards Points: 6,995
We do what Joed does all the time. Keeping it watered is a PITA.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
