Are You Supposed To "knock Down" Orange Peel? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By mark sr
  • 1 Post By Gymschu
  • 1 Post By farmerjohn1324
Old 04-01-2019, 10:49 AM   #1
Rewards Points: 54
Are you supposed to "knock down" orange peel?
Last time I used orange peel in a can, I didn't flatten it at all. It looked terrible and I had to scrape the wall before painting.
This time, I used a knockdown knife to flatten it a bit.
farmerjohn1324 is offline   Reply With Quote
Old 04-01-2019, 11:02 AM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,668
Re: Are you supposed to "knock down" orange peel?
Tell us how you applied it..... spray cans or texture gun.....
Ooops... see you used a can, I assume on a fine orange peel dial on it's nozzle..... What looked terrible....rather single bumps..??? might have been put on too sparsely.
What is the picture of....after you knocked orange peel down...?
NO, you normally do not knock down orange peel.... you do need good and complete coverage though.
MTN REMODEL LLC is offline   Reply With Quote
Old 04-01-2019, 11:06 AM   #3
Rewards Points: 54
Spray can.
After I knocked it down.
So I'm supposed to cover every square millimeter of the wall? I still think it would have protruded out than the rest of the wall, but I suppose that's because the rest of the wall is not orange peel. I'm not really sure what the rest of the wall is, honestly.
Old 04-01-2019, 11:31 AM   #4
retired painter
Rewards Points: 594
All orange peel textures aren't the same, a lot depends on how thick/thin it was mixed and how heavy/light it was applied. The main thing with touch ups is to mimic the texture that is already there. It's not that big of a deal to wipe/scrape it off while wet or sand down when dry and try again if the texture isn't close enough.
MTN REMODEL LLC likes this.
mark sr is offline   Reply With Quote
Old 04-01-2019, 11:57 AM   #5
Super Moderator
Gymschu's Avatar
Rewards Points: 6,628
If you're using the spray cans, that wall is gonna cost you a fortune! Some orange peel DOES NOT need knocked down. Usually the hopper gun version of OP is sprayed on and left to dry as it is on the wall. That's the idea behind it, to save the time of messing with it by knocking it down. Of course it all depends on air pressure and the consistency of the mud. Do you have any drywall guys in your area who could talk you through how to do knockdown with a hopper gun?
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 04-01-2019, 12:06 PM   #6
Rewards Points: 54
This is just covering a patch. I already sprayed everything I need to spray. It's in a relatively inconspicuous area, so not a huge deal if it doesn't match perfectly.
Gymschu likes this.
Orange Peel Texture Help please kalaniwavo Painting 12 07-13-2015 02:48 PM
Best primer over orange peel texture? GFW Painting 2 12-04-2008 04:24 PM
Whats the best way to remove orange peel wall texture? billyg Carpentry 2 01-30-2008 04:09 PM
Same Ceiling: orange peel and knockdown sir_rob Painting 17 10-01-2007 04:28 PM
Knockdown ceiling : My walls are orange peel.. Arkanoid Remodeling 4 08-07-2007 12:23 PM
