Water Damage To Wall Next To Glass Shower Door - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By chakangt
Old 04-01-2019, 04:55 PM   #1
Rewards Points: 8
Water Damage to wall next to glass shower door
We bought a house 2 years ago and the wall was repaired for sale. 2 years later we are getting water damage at the wall next to the shower. I recaulked but we continue to have an issue. I think that water is getting behind the caulk, and then draining over the lip at the front corner (where the damage is).
When I stuck a level on the tub, it seemed to be tilted correctly so water would run back into the tub from the lip.
Thoughts on the repair? just replace the drywall and paint? I've heard from folks that drywall shouldn't be that close to a glass shower door. Any thoughts on how to eliminate the problem? should I create a caulk dam at the edge to keep water from draining over the edge and onto the drywall?
I don't believe water is running down the shower tile and past the edging on the door, but I could be wrong.
(if you click on the pictures, it seems they rotate to the right orientation)
Thank you for your thoughts!
Water Damage to wall next to glass shower door-img_7368.jpg   Water Damage to wall next to glass shower door-img_7367.jpg   Water Damage to wall next to glass shower door-img_7366.jpg
chakangt is offline   Reply With Quote
Old 04-01-2019, 05:30 PM   #2
retired framer
Rewards Points: 14,102
Re: Water Damage to wall next to glass shower door
If water is getting behind the tile and in the lip on the back of the tub, that is where it would come out. Often you see another 6" of tile down that side.
There is a clear vinyl trim you can put in the corner to seal the door to tile.
https://www.lowes.com/pd/DreamLine-8...ing/1000498581
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old 04-02-2019, 05:47 AM   #3
retired painter
Rewards Points: 540
Is the track on the tile caulked?
Drywall is installed that close to tile all the time without issues. Once the water is stopped so will the damage.
mark sr is online now   Reply With Quote
Old 04-02-2019, 02:21 PM   #4
Rewards Points: 8
Thanks Nealtw. The door already has weather stripping on it, which moves with the door as it opens and closes. It seems like the vinly product you mentioned would probably be useful on a non-moving part... but I'm not sure I see it on a moving edge (my apologies for not including a picture in the "open" position,
So really, I just need to chase down how the water is getting back there, whether through the existing silicone, or elsewhere (maybe slow leak in the diverter somehow...)
it also sounds like to chase down that leak, I shoule probably remove that drywall so I have access.
Nealtw likes this.
Old 04-02-2019, 02:24 PM   #5
Rewards Points: 8
Mark Sr., There is a weatherstripping on the tile side of the door that is pretty similar to this...
https://www.homedepot.com/p/Showerdo...BS36/205438352
Old 04-03-2019, 07:45 AM   #6
Rewards Points: 238
Is there top of the bathtub tilted toward the wall? If so it just seems water is going into the tile through the grout and draining that direction...
Sdiver2489 is offline   Reply With Quote
Old 04-05-2019, 12:46 PM   #7
Rewards Points: 8
@Sdiver- the last time I checked it seemed to. I'll check again. I'm trying to remember if the tub was caulked empty or full of water... as that may have led to the separation of the caulk and water getting underneath/behind it and running over the corner edge. I can tell you on further inspection that the bottom lip (where the caulk meets the tub) is not a tight seal in some places... so I'm going to recaulk this weekend.
Tags
damage , leak , shower , water
Black smelly water Gradydane Plumbing 3 11-30-2018 08:42 PM
water damage in wall? dleclair General DIY Discussions 6 03-25-2018 11:53 AM
Make my own shower door? sgbotsford Kitchen & Bath Remodeling 9 02-03-2018 06:59 AM
options for a not so squared shower.. glass door vote4Pedro Windows and Doors 6 03-05-2012 08:10 AM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 07:22 AM
