Using 1/4 Drywall For Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree13Likes
Old 07-06-2019, 09:33 AM   #1
Rewards Points: 166
using 1/4 drywall for ceiling
Hello all, I'm helping my cousin to fix up her sister's house so that she can sell it. this will be located in the basement area that surrounds her garage. I was contemplating about using 1/4 inch drywall for the ceiling since I'll be working by myself and figure the thinner stuff would be more manageable. I'm going to use 1/2 on the walls. any pro's and con's about this? Thanks
woodypecker is offline   Reply With Quote
Old 07-06-2019, 09:58 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 4,304
Re: using 1/4 drywall for ceiling
1/4" is not acceptable for a ceiling as a primary surface. 1/2" minimum with 5/8" is preferred. Rent a sheetrock dolly to help hoist them up there. Much easier and not all that expensive.
Profkanz likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 07-06-2019, 01:35 PM   #3
Rewards Points: 160
100% what Chandler posted
finisher65 is offline   Reply With Quote
Old 07-06-2019, 02:38 PM   #4
retired painter
Rewards Points: 506
I'd be leery of 1/4" drywall being used to laminate over a ceiling. 1/2" is ok for ceilings that have the joists on 16" centers, 5/8" is preferred and needed if the the ceiling joists are on 24" centers.
If you don't want to rent a lift you can take a 2x4 and make a T that you can prop one side of the drywall up with while you push up and screw the other side.
mark sr is offline   Reply With Quote
Old 07-06-2019, 06:45 PM   #5
Rewards Points: 2,968
I thought I was the only one who did that!
CaptTom is offline   Reply With Quote
The Following User Says Thank You to CaptTom For This Useful Post:
mark sr (07-07-2019)
Old 07-06-2019, 06:55 PM   #6
Naildriver
chandler48's Avatar
Tongue in cheek, but you could take an 8' step ladder and do the same, except you'll never be able to get the ladder out of the room.
GrapeApe likes this.
Larry......
Old 07-07-2019, 06:07 AM   #7
retired painter
Rewards Points: 506
I learned that trick from a drywall hanger many moons ago.
You do want to make the top of the T about 1" lower than the unfinished ceiling so there are no issues removing it. It works well to hold up one side while you screw the other side, then you just walk your way over to fasten that side.
Another trick I learned from hangers is to preset nails along the perimeter of the board so you can quickly secure the board - then go back and screw the rest. The nails under tape are unlikely to pop later on.
Nealtw likes this.
Old 07-07-2019, 07:51 AM   #8
Rewards Points: 784
I'd rather make a I than a T.
JLawrence08648 is online now   Reply With Quote
Old 07-07-2019, 07:59 AM   #9
retired framer
Rewards Points: 17,374
CaptTom likes this.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 07-07-2019, 08:11 AM   #10
Rewards Points: 160
Originally Posted by Nealtw View Post
Except he's lining up the butt joints. Big no no
Old 07-07-2019, 08:18 AM   #11
retired framer
Yes but it shows what some one with no experience can figure out.
figure 7-14
Old 07-07-2019, 08:35 AM   #12
Rewards Points: 4,990
Would doubling up on the 1/4" meet the 1/2" minimum? (Not that it's a great idea but if someone was able to manhandle 1/4", but not 1/2".)
huesmann is offline   Reply With Quote
Old 07-07-2019, 09:28 AM   #13
Hammered Thumb
Rewards Points: 2,530
Maybe if you glued them together first. You might get some waviness just screwing the first layer up before the second layer goes over top. But why go to that much trouble? Just start with 1/2", use a lift, a prop, or find a helper for the ceiling.
3onthetree is offline   Reply With Quote
Old 07-07-2019, 09:30 AM   #14
retired framer
1/4" will weigh 1/2 as much and break 2 x easier over head.
GrapeApe and Profkanz like this.
figure 7-14
Old 07-07-2019, 09:44 AM   #15
Rewards Points: 6,358
How about a T&G ceiling tile.?
Cost a little more then drywall, but much lighter, easier to install, and when your done hanging the tiles your done.
They come in many sizes and shapes to choose from.
One person can easily hang them and in one day.
https://www.google.com/search?biw=19....0.g12qJ2l-W-s
ron45 is offline   Reply With Quote
