Skim Coat On Top Of Paint - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 1 Post By mark sr
  • 2 Post By Sir MixAlot
  • 1 Post By DIY1234
  • 1 Post By MTN REMODEL LLC
Old 10-18-2017, 11:02 AM   #1
Rewards Points: 16
Skim coat on top of paint
Hi all! I'm new to this group and want to Thank U ahead of time for any advice with this project. Initially I replaced the ceiling in the bathroom but was in a bit of hurry and not enough experience to do a decent drywall compounding/sanding job because my girlfriend was coming back and I wanted it to look finished upon her arrival. When I was taking down the old sheetrock I ripped some of the paint and paper off the walls. With that said I was able to sand and use primer on the walls and put 2 layers of Satin paint on the ceiling. After a couple of days of looking at it I was not happy and decided to redo some of the corners and seams on the ceiling. About 3 weeks have passed between now and initial project. Currently I?m almost done with sanding down the areas on walls and ceiling. Below are the several questions/concerns that I have and need your input.
1. After restarting the project and sanding/scraping down ceiling areas I was able to pull away pieces of paint and no I did not use primer on the ceiling because Home depot folks recommended using the paint and primer in one. The concern is that the paint will sag or fall off at some point after I prime or just repaint. Is there something I can do to make sure that it does not happen?
2. Once the first question is resolved should I put a skim coat over the walls and ceiling before priming and/or painting?
DIY1234 is offline   Reply With Quote
Old 10-18-2017, 11:30 AM   #2
Rewards Points: 1,066
Re: Skim coat on top of paint
Skim coat of what?
NotyeruncleBob is offline   Reply With Quote
Old 10-18-2017, 11:34 AM   #3
retired painter
Rewards Points: 196
Most likely cause for the peeling paint is drywall sanding dust that wasn't removed prior to painting. IMO the primer in the paint is more of a marketing ploy than anything else, whenever a primer is needed you should use a dedicated primer tailored for the job at hand.
There normally isn't any issues with skim coating over latex paint, if the paint has a sheen - scuff sand first.
Gymschu likes this.
mark sr is offline   Reply With Quote
Old 10-18-2017, 01:45 PM   #4
Rewards Points: 4,234
Mark steered you right. Hopefully you've learned the folks at the store did not and will be shopping at a paint store instead of a paint department in the future.
stick\shift is offline   Reply With Quote
Old 10-18-2017, 05:24 PM   #5
Rewards Points: 16
I was thinking using easy sand 45 joint compound that I used to on the drywall
Old 10-18-2017, 05:27 PM   #6
Rewards Points: 16
Thanks Mark! I used satin paint on the ceiling but think that I will need to scuff sand first anyway
Old 10-19-2017, 07:00 AM   #7
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 1,142
I would use an all purpose joint compound instead of the 45 minute mud.
Reason being the AP joint compound has more glue in it and will adhere better.
If you read the directions on the 45 minute mud it probably say's "Do not use for skim coating".
Here's a couple different options fro skim coating:
Hope that helps and Good luck! -Paul
MTN REMODEL LLC and Gymschu like this.
-Paul
Checkout my YouTube Channel with 61,000 Subscribers and over 10,000,000 Views
https://www.youtube.com/paulpeck
Sir MixAlot is offline   Reply With Quote
Old 10-24-2017, 05:52 AM   #8
Rewards Points: 16
Hope that helps and Good luck! [IMG class=inlineimg]http://www.diychatroom.com/images/smilies/thumbsup.gif[/IMG] -Paul
Thanks Sir MixAlot!
Sir MixAlot likes this.
Old 12-19-2017, 07:42 AM   #9
Thanks Sir MixAlot!
@DIY1234 , Always happy to help my friend!
-Paul
Old 12-19-2017, 09:49 AM   #10
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,390
https://youtu.be/jeGWbgAUvCM
https://youtu.be/XZ9MtOyIBqU
Sir Mixy......
Just a quick question.... not so much about skim coating as more of a general clarrification....
I've always thought durabond or the easy sand products were stronger and often recomended for the initial tape coat... but you mention AP has more glue.
Am I wrong... or misunderstanding as to the relative differences.????
TIA
MTN REMODEL LLC is offline   Reply With Quote
Old 12-19-2017, 01:24 PM   #11
Originally Posted by MTN REMODEL LLC View Post
Sir Mixy......
TIA
Yes, for first coating fiberglass mesh tape, bedding tape or even second coating hot mud is good.
The hot mud has more strength in bulk/thickness. Not so much with thin coats. Escpecially if it's thinned with water for skim coating.
Hope that helps, -Paul
-Paul
The Following User Says Thank You to Sir MixAlot For This Useful Post:
MTN REMODEL LLC (12-20-2017)
Lead Paint Follow-Up RoughDraft Painting 24 06-18-2013 07:31 PM
A Home Depot/Behr paint experience jeffnc Painting 31 05-25-2013 11:14 AM
Please help (again):Why is my SW Pro Classic paint sagging on the second coat? Fun2Learn Painting 7 12-05-2011 10:12 AM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 10:00 AM
