Replaced Bathroom Vanity - Need To Repair Wall Damage - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By de-nagorg
Old 12-30-2017, 10:08 PM   #1
Rewards Points: 232
Replaced Bathroom Vanity - Need to Repair Wall Damage
I have a small office condo, and I'm gradually making improvements. I am in the process of replacing the bathroom vanity, and the new one is a bit smaller (in depth and height). I have a bunch of drywall imperfections, and I don't know the best way to fix them. At the back left, there is a hole where the old formica met the wall. It's approximately 1"x4". I was thinking that I could cut a piece of drywall and screw it into place. From there, I would tape it, spackle, and then sand. I don't know if that's the best way to repair it. I also have white space in the front left. It's very rough, and there is a bunch of brown paper showing. I don't know the best way to get it smooth. I have a similar issue near the backsplash. There is brown paper showing. Some of it will be hidden by the caulk, but I think it will still be partly visible. I would like to be able to get the walls as blemish free as possible. I'll buy whatever is necessary to do the job right. If anyone could give me any suggestions/advice, I would greatly appreciate it.
Replaced Bathroom Vanity - Need to Repair Wall Damage-img_0703.jpg   Replaced Bathroom Vanity - Need to Repair Wall Damage-img_0705.jpg   Replaced Bathroom Vanity - Need to Repair Wall Damage-img_0704.jpg
chris87 is offline   Reply With Quote
Old 12-30-2017, 10:38 PM   #2
JUSTA MEMBER
Rewards Points: 4,258
Re: Replaced Bathroom Vanity - Need to Repair Wall Damage
Patch the one hole using a sound support behind the new piece of drywall, then use joint compound (spackle), to fill any small holes / lines.
Sand and then paint.
Magic it's all gone.
Then install the new vanity.
ED
chandler48 likes this.
de-nagorg is offline   Reply With Quote
wall mounted bathroom vanity light install Q's gnojham Electrical 2 07-07-2017 05:50 PM
Mysterious odor in my bathroom near Vanity / Sink MountainLion Plumbing 10 07-16-2014 10:21 PM
NEC - what is the purpose of some of these codes ? chez bouton Electrical 32 12-17-2013 02:04 PM
small gap between vanity and wall, how do i screw it in? cantgetenuff Building & Construction 8 03-09-2011 11:15 AM
How to remove cultured marble bathroom vanity countertop goshenplumber Building & Construction 4 03-04-2011 04:56 PM
