Repair Small Holes In Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree16Likes
Old 01-12-2018, 10:24 AM   #1
Rewards Points: 12
Increasingly I am being asked to repair small holes (usually no bigger than 150x150mm) and I usually have to make several visits. Obviously this makes a one off hole repair quite expensive.
Typically I would apply a patch then apply a skim of top coat. If dry enough I would then apply a second coat an hour or so late,r or the following day if I go to other repair jobs. Then I go back to sand, either on the second or third visit, depending on when I applied the final coat.
Is there a way of speeding up the drying time of both coats so I can apply and sand within a couple of hours? is there an additive available, or a trick of the trade I have not heard of?
I am more of a handyman that a drywall pro, so any advice would be greatly appreciated. Thanks
JsyBean is offline   Reply With Quote
Old 01-12-2018, 10:51 AM   #2
Guapo
Rewards Points: 11,950
Re: Repair Small Holes In Drywall
There are light weight patch products that dry quickly. That's one choice. Another choice is a setting product such as Durabond which also sets quickly. The only problem is that if you use a quick drying/setting product, you have to work fast because it will dry before you get it on then wall.
JsyBean likes this.
Guap0_ is offline   Reply With Quote
Old 01-12-2018, 10:52 AM   #3
Rewards Points: 144
I am not a drywall person but you can speed up the set time.
Find some Hydrocal Gypsum Cement mix and apply to fill the hole in the drywall it will set hard in about 20 min. Than apply a Venetian finish plaster trowel smooth NO SANDING would be required total time 30 min.
JsyBean likes this.
ClarenceBauer is offline   Reply With Quote
Old 01-12-2018, 12:03 PM   #4
Super Moderator
Gymschu's Avatar
Rewards Points: 142
I repair drywall almost on a daily basis. Speeding up things just requires the use of the aforementioned Durabond (thanks Guap0) or Sheetrock's Easy Sand. I use a lot of the 5 minute stuff just to get the holes filled and get them drying quickly. Then you can switch to the 20, 45, or 90 minute stuff for additional coats so you don't have to rush. It used to be that fast-setting joint compound was hard to sand. It's much easier to sand these days, so I often do not apply a topping coat from a bucket. I do like it to dry overnight if possible, but, if not, that's ok too, it still sands rather easily and accepts a coat of primer without issue.
I have bags of the "EasySand" in my truck at all times because there's always holes to fill and areas to patch..........
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 01-12-2018, 05:54 PM   #5
Rewards Points: 12
Thank you. How fast does Durabond set, and can it be sanded?
Old 01-12-2018, 05:57 PM   #6
Rewards Points: 12
Thanks. Can it be sanded if required?
Old 01-12-2018, 06:03 PM   #7
Rewards Points: 12
Excellent, thank you, this is really helpful. Easy, or even relatively easy sanding is always appreciated.
Gymschu likes this.
Old 01-12-2018, 07:33 PM   #8
Rewards Points: 144
If it is as smooth as glass WHY sand it?
JsyBean likes this.
The Following User Says Thank You to ClarenceBauer For This Useful Post:
JsyBean (01-13-2018)
Old 01-12-2018, 07:57 PM   #9
Guapo
Mr Bean, durabond can be sanded.
JsyBean likes this.
The Following User Says Thank You to Guap0_ For This Useful Post:
Old 01-13-2018, 06:39 AM   #10
retired painter
Rewards Points: 864
But I prefer not to!! about the only product I know of harder to sand than Durabond is Durham's Rock Hard Putty. The neater Durabond is applied, the better!
JsyBean likes this.
mark sr is online now   Reply With Quote
The Following User Says Thank You to mark sr For This Useful Post:
Old 01-13-2018, 11:47 AM   #11
Super Moderator
Gymschu's Avatar
Rewards Points: 142
The Sheetrock brand, Easy Sand, is, like the name states, easy to sand. It sands just like regular joint compound. As far as setting times, they all set in about the time listed on the bag. 5 sets in about 5 minutes or less.......20, in 20 minutes or less.......etc.
For nail holes, etc. I just mix up some of the Easy Sand 5 in a plastic cup, roll it up into a ball and push it into the hole(s). If they require more "fill" I just repeat the process after about an hour. It's ready to sand, prime, and paint after about another hour of good dry time.
JsyBean likes this.
The Following User Says Thank You to Gymschu For This Useful Post:
Old 01-13-2018, 12:51 PM   #12
firehawkmph's Avatar
Rewards Points: 2,514
I patch holes like Gymschu stated above. First two coats with easy sand, last coat I will do with USG's Dust Control joint compound. If I'm not coming back for anything else, I'll use a hair dryer to dry the last coat and then sand it. It's very thin and dries out in a few minutes.
Mike Hawkins
Gymschu and JsyBean like this.
firehawkmph is offline   Reply With Quote
Old 01-14-2018, 01:18 PM   #13
Rewards Points: 12
Thanks for all of your help guys. I have just updated my profile as I am new here. I am actually in the United Kingdom, so I will need to check which of these great products you have recommended are available in the UK.
firehawkmph likes this.
Old 01-14-2018, 03:20 PM   #14
Rewards Points: 2,974
I heard that dust control has wax in it, and can cause adhesion issues. There was a long thread about that in the painters forum a while back. I have no experience in the matter, just saying.
JsyBean likes this.
woodco is offline   Reply With Quote
The Following User Says Thank You to woodco For This Useful Post:
JsyBean (01-14-2018)
Old 01-14-2018, 03:49 PM   #15
Rewards Points: 144
In the UK you can contact Historic Scotland.
www.historic-Scotland.gouk.
They can give you all the info you should need.
Question about Inside and Outside corners in Drywall repair work DIYusually Drywall & Plaster 19 01-22-2016 12:16 PM
drywall repair business thoughts drew53813 Drywall & Plaster 16 08-20-2015 09:24 AM
do you have to tape joints? begal Drywall & Plaster 34 08-09-2015 09:42 AM
Drywall repair REXAMUS Drywall & Plaster 7 12-21-2011 04:24 AM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 02:08 PM
