Remove Baseboard Without Damaging Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 2 Post By Mike Milam
  • 2 Post By NotYerUncleBob2
  • 1 Post By Nealtw
Old 10-31-2018, 10:39 AM   #1
Remove baseboard without damaging drywall
I would like to remove some of my baseboard molding. It's oak, about 3 1/2" high, and is nailed into wall studs and, in places, into the bottom plate. The wall surface is 1/2" drywall.
What's the process for doing this without damaging the drywall?
SOLIDAGO is offline   Reply With Quote
Old 10-31-2018, 11:11 AM   #2
Mike Milam's Avatar
Rewards Points: 152
Re: Remove baseboard without damaging drywall
I usually locate the nails holding it and with a nail set, drive the nails on through. Remove the baseboard and then pull the nails. When you put it back you can use the next size up nail to reattach.
coupe and lenaitch like this.
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is online now   Reply With Quote
Old 10-31-2018, 11:18 AM   #3
Rewards Points: 1,058
Go slow. Be patient.
Score the top of the moulding where it meets the wall to break the paint bond (assuming it's painted or the wall paint has met the trim).
Get a wide flexible scraper and slide that behind the trim. Wiggle it a little bit to get a little gap. Use a stiff scraper or a thin pry bar to pull the trim. You don't have to pull it completely off, just get it separated from the wall a little bit. Slide down a little bit and repeat.
Once you've gone the whole length, go back and pull it a little further.
To save and reuse the trim it's often better to pull the nails through the back instead of trying to pull them out the face. A nail puller (kinda like pliers) or even vice grips will do short work of pulling the nails through by clamping on the nail right at the surface and using leverage to pull it through.
Mike Milam and Johnny_inFL like this.
NotYerUncleBob2 is offline   Reply With Quote
Old 10-31-2018, 11:25 AM   #4
retired framer
Rewards Points: 9,558
Mike Milam likes this.
Old 10-31-2018, 09:32 PM   #5
Usually Confused
lenaitch's Avatar
Rewards Points: 1,326
I usually do as UncleBob described but Mike's approach is good too. Cutting/releasing the paint or caulk bond between the wall and trim is important to prevent wall damage. If the trim was attached with a pin nail as opposed to a finishing nail it should come off easier and leave a smaller hole on the outer surface.
For the prying part, I find a 'restorer's cat's paw' to be the handiest darn thing.
_________________________________________
Pro patria
lenaitch is offline   Reply With Quote
Tags
drywall , molding
Removing Baseboard Heater Covers for Drywall Fenwayhhh HVAC 0 10-18-2017 12:00 PM
Gap between drywall and baseboard Pardner Drywall & Plaster 5 07-02-2013 11:42 AM
How to fix a baseboard heater to drywall with no studs?! gloriousglenn HVAC 9 11-30-2012 09:22 AM
Remove Drywall installed over OSB jrunde Drywall & Plaster 8 03-04-2011 07:42 PM
What's the best way to remove Plaster/Lath walls and replace with Drywall psubaron Building & Construction 31 02-14-2011 11:20 AM
