Remodel With Old Adhesive And Tears - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By mark sr
Old 01-01-2018, 03:46 PM   #1
Rewards Points: 2
Remodel with old adhesive and tears
Hello,
We are remodeling our master bath. There was wood paneling installed on top of drywall. When we removed the paneling, the adhesive either tore off the top paper of the drywall underneath or is now left behind on top of the drywall.
Either way, we have drywall with both tears in the top paper layer and old, yellowish-brown adhesive that will not chip off. Our plan is to hire someone to apply a knock down texture, but we would like to do the prep work ourselves.
What is the best way to approach this? It's not necessary for it to be absolutely smooth, since we will be texturing so we're wondering if we could sand down the old adhesive and roll on Kilz primer over it all to cover the tears and any remaining adhesive?
azbrad is offline   Reply With Quote
Old 01-01-2018, 04:05 PM   #2
Guapo
Rewards Points: 11,950
Re: Remodel with old adhesive and tears
You're on the right track. Scrape whatever you can, roll the sealer & skim coat the wall. That's all that's needed.
Guap0_ is offline   Reply With Quote
Old 01-01-2018, 04:42 PM   #3
retired painter
Rewards Points: 196
Where the drywall paper is torn exposing the gypsum you'll need either an oil base primer or Zinnser's Gardz, that will prevent the moisture in the joint compound or latex primer from causing more damage.
Sir MixAlot likes this.
mark sr is online now   Reply With Quote
Old 01-01-2018, 05:20 PM   #4
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 1,142
Yep. Gardz is a must on the torn drywall paper.
Here ya go.
-Paul
Checkout my YouTube Channel with 61,000 Subscribers and over 10,000,000 Views
https://www.youtube.com/paulpeck
Sir MixAlot is offline   Reply With Quote
The Following User Says Thank You to Sir MixAlot For This Useful Post:
chrisn (01-02-2018)
Removing Adhesive from concrete jillofalltrades Flooring 5 07-22-2011 06:13 PM
