Old Drywall & Insulation "Issue" - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-22-2015, 02:37 PM   #1
Rewards Points: 49
I own a 1906 Victorian. In the rear of the unfinished attic there's a large finished room I'm converting to an office. This room is open studs on the exterior and is insulated entirely in whole newspapers form the late 30's and early 40's.
In putting in a baseboard heater I found that the exterior facing wall (the wall that faces outside with windows in it) also has said newspapers between the studs.
I'm worried about cutting up the drywall to remove and replace the insulation because of asbestos concerns. The room was built in at least the 30's.
So how do I deal with the insulation in that wall? Leave it alone? Tear it out?
Any ideas would be really appreciated.
jrdamien is offline   Reply With Quote
Old 09-22-2015, 09:21 PM   #2
PE Mechanical Engineer
Thunder Chicken's Avatar
Rewards Points: 886
You can have the drywall sampled and tested for asbestos. Hopefully someone familiar with this will tell you how to get this done. If you don't have anyway, new insulation would probably be a good idea. If you do have asbestos, well, the newspapers worked since the 40s...
Thunder Chicken is offline   Reply With Quote
Old 09-22-2015, 10:21 PM   #3
Rewards Points: 18,382
1906 tells me balloon wall constrution.
All that old newspaper needs to go. Nothing but a fire hazzard.
Walls need to be fire blocked.
Hard to tell how much or what type insulation, venting you need because no location is mentioned this website may help.
http://www.energystar.gov/index.cfm?...sulation_table
Drywall has no asbestos.
Old 09-22-2015, 10:51 PM   #4
Rewards Points: 6,236
They used newspaper back then because that's what they had and it was better than nothing (barely). New insulation would be about 100 times better.
Entering your general location can help with answering a lot of times
The Following User Says Thank You to ToolSeeker For This Useful Post:
joecaption (09-22-2015)
Old 09-22-2015, 10:59 PM   #5
griz's Avatar
Rewards Points: 572
You sure it's drywall & not old plasterboard?
Yes, drywall can contain asbestos
check these guys out for testing.
http://www.prolabinc.com/asbestos-test-kits.asp
griz is offline   Reply With Quote
Old 09-23-2015, 01:35 AM   #6
Rewards Points: 49
Fire is certainly one of my top concerns, thus the question.
I'm in Minneapolis. I'll do as great an R roll insulation as can fit in the cavity.
But some drywall did have asbestos.
Old 09-23-2015, 01:35 AM   #7
Rewards Points: 49
I'm 90% it's drywall. Feels like it. Looks like it. Cuts like it.
Old 09-23-2015, 02:23 AM   #8
Rewards Points: 6,652
Anything from Hay, Straw, Newspapers, Walnut Shells. You name it, they used it. The newspapers that people pull from walls, they usually end up getting them flattened out, so that they can be placed in a book. Especially if there is something of interest on the pages from that time period.
I highly doubt that Horse Hair plaster will have any Asbestos.
Old 09-23-2015, 03:41 AM   #9
Rewards Points: 49
It's not plaster. It's drywall. If it's from the 40's or before it's likely gypsum, correct?
I thought it was widely recognized that both drywall and gypsum contained asbestos/.
Old 09-23-2015, 06:56 AM   #10
Rewards Points: 886
Old drywall (it has been available since the 30s, possibly earlier) DID contain asbestos, or at least the joint compound did.
Old 09-23-2015, 06:59 AM   #11
Rewards Points: 886
It's what was called gypsum board, essentially an early form of drywall. It definitely existed in the 30s and 40s.
Old 09-23-2015, 05:23 PM   #12
Rewards Points: 49
The piece that was already removed had no markings on the rear of it.
Old 09-25-2015, 01:36 AM   #13
Just good ole fashion Drywall that used to have the heavier paper. Before that stuff, you had "Gyprock". It was 18"x48" sections, that had two layers, the boards had holes in them, so that they would hold the Plaster coat.
I have it in my house, and when I gutted our Bathroom and took down a wall in our Kitchen. It turns into a huge dusty mess. Also good for dulling Multi-Tool blades and Dremel roto-zip bits. Inside corners would be Metal Lathe to help keep the corners solid.
Old 09-25-2015, 02:32 PM   #14
Rewards Points: 49
Well it came out easy enough. Not very dusty, actually, but I scored it and tore it down by hand.
No metal corners at all, just taped.
The paper insulation, though...what a tremendous pain in the ass. It's all whole papers, stapled together, bound in kraft paper and nailed to the studs with a board over everything.
Old 09-25-2015, 03:48 PM   #15
Remember DO NOT compress the insulation as this will cut down on the effectiveness.
Colonial Split level drew7ster Insulation 11 01-09-2013 04:44 PM
Repair of drywall. Noticed bad insulation yardlady General DIY Discussions 3 09-04-2011 08:50 AM
Holding Insulation on ceiling without drywall? EricCJacobson Insulation 10 08-28-2011 09:36 PM
adding insulation on top of drywall terry hinkley Insulation 2 06-14-2011 05:55 PM
Replacing drywall, do I need to replace the insulation? RyanD Drywall & Plaster 4 06-11-2009 09:46 AM
