No Wooden Studs Behind Plaster Wall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 07-31-2018, 12:02 AM   #1
No wooden studs behind plaster wall
Our bathroom condo was original from the 60’s. The walls were plaster on mesh. All 4 walls had tiles at least 60% up the walls. We had all tiles and walls demolished down to the frame. The idea was to add in new drywall/backerboard to the wooden studs.
After the demo we saw that 2 out of the 4 walls don’t have wooden studs and have a metal “grid” instead where the mesh was attached to.
The wooden “frame” in the photos was behind a medicine caninet mirror.
How do we add drywall to the walls without wooden studs?
Thank you
No wooden studs behind plaster wall-ac423023-5320-4c04-928c-2583d527c013_1533009355244.jpg   No wooden studs behind plaster wall-ff70848c-a582-4977-91fb-efa19e70d69e_1533009385663.jpg   No wooden studs behind plaster wall-c8ba830b-988b-4ed1-893d-6f393aad6d83_1533009426169.jpg   No wooden studs behind plaster wall-b6ea8831-26b7-465f-9922-723e28cd0948_1533009497148.jpg
Motolog is offline   Reply With Quote
Old 07-31-2018, 12:13 AM   #2
retired framer
Rewards Points: 4,780
Re: No wooden studs behind plaster wall
Hard to know something that stood for 60 years. space saving a fire proof.
I would just strap it with 1x4 and carry on.
Cut chunks of 2x4 with a slot in them so they fit around the pipe from the back and screw the strapping to them.
Nealtw is offline   Reply With Quote
Old 07-31-2018, 08:21 AM   #3
Rewards Points: 282
What you have is Cold rolled channel iron wire tied. I can't tell from the photo's it may be 1 1/2 inch carrying channel with 3/4 inch runners.
How is it supported at the top & bottom if it has the channel track than remove the horizonal channels , it may also have what they call shoes & than wire tie furring channel to the remaining vertical channels ( Hat Track ) the furring channels come 1/2" - 7/8" & 1 " see if you can find the 1/2 inch it may very well match the original depth of the plaster than you will have to use the proper drywall to match the tile depth.
Contact a good commercial metal framer in your area they should be able to give some more advice.
ClarenceBauer is online now   Reply With Quote
Old 07-31-2018, 08:33 AM   #4
Rewards Points: 282
I just picked up something you have what is known as a ROCK LATH support system this may change how the wall is attached at the top & bottom.
Old 08-06-2018, 05:33 PM   #5
Rewards Points: 3,562
that sure doesnt look like rocklath to me....
Originally Posted by Bud9051
Of course they had already been around for over 200 million years but on a planet that could go for billions of years maybe captain Kirk would have had big teeth and a long tail.
That Guy is offline   Reply With Quote
Old 08-06-2018, 05:39 PM   #6
retired framer
https://inspectapedia.com/interiors/...Metal_Lath.php
That Guy likes this.
Old 08-06-2018, 06:58 PM   #7
Rewards Points: 282
If it is not RocK LATH how do you explain the metal Clip at the joint holding the sheathing to the channel Iron ? Also note the size of the Rock Lath Joints 16 inches X 48 inches.
The side with the metal lath & plaster is High Rib Lath with a base coat of cement plaster a tile bed coat plus tile. My estimate is that the plaster is 3/4 inch plus the bed coat plus tile = 1 & 1/4 inches thickness. Have installed many systems like this.
NEALTW your illustration is a suspended metal lath ceiling system very commend in a plaster system but not related to the Rock Lath system.
The Following User Says Thank You to ClarenceBauer For This Useful Post:
Nealtw (08-06-2018)
Old 08-06-2018, 08:55 PM   #8
I must be blind... theres a wall behind the one removed with what looks like rock lath, but I am not seeing it in this bathroom...
And in the house I grew up we had 2 suspended metal lath ceilings, one 14x14 and the other 14x18.... both installed by my grand father and dad.
Old 08-06-2018, 09:54 PM   #9
Rewards Points: 282
What is supporting the Rock Lath sheathing behind the metal lath & plaster you see ?
Than answer the OP question as to WHY no wood STUDS ?
Now explain what is supporting the Cement plaster & Tile ?
I stated that it is a metal support system as you can find in the USG hand book dated P-15 USG Rev. 5/64. & you can find the CLIP I asked about on page 29 of the same book. The clip is " TL-1 TRUS-LOK FIELD CLIP " it is a clip specially formed & designed to provide a rigid attachment of 3/8" ROCKLATH plaster base to TRUSSSTELL studs. Can YOU give an answer as to how the sheathing behind the Tile & plaster is supported & also what is holding up the plaster & tile ? I can STATE that the metal GRID system is supporting both wall substrates up. If you need the info from the USG booklet that I have in front of me I can tell you that there are 26 different clips that could be included it that metal support system & you can find them on page 26 , 27 , 28 & 29 of the above USG HAND BOOK. As for a metal supported plaster grid system in stalled I can STATE that the last one of many that I installed was in 2011 in a Banks parking garage. Also I have installed many supported walls as you see in the OP's questions.
spliced studs on balloon frame wall jb8578 Building & Construction 4 06-01-2017 01:59 AM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 05:53 PM
Need Some Advice About A House With An Issue neutropia General DIY Discussions 7 01-29-2017 07:46 AM
Strength of knee wall with metal studs Momx2 Concrete, Stone & Masonry 8 09-28-2015 09:09 AM
The stringer on my stairs is pulling away from the wall/ studs. georgiabiker Carpentry 10 01-24-2013 04:53 PM
