Mud And/or Tape Top Of Half Wall? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Weizilla
  • 1 Post By mark sr
Old 12-20-2017, 11:01 PM   #1
Rewards Points: 18
Mud and/or Tape Top of Half Wall?
I have a half wall which I'm in the process of finishing up.
For the top, I'm thinking of screwing on some 1x8 boards, adding any shims as needed to level it out. The 1x8 will over hang each side by 1 1/4" which I'll tack on with some moulding followed by caulk on all seams.
Does this seem like a reasonable plan? Do I need to mud and/or tape the top inside corners where the drywall meets the 1x8 before the moulding?
Pic: http://i.imgur.com/a9xRwbp.jpg
Nealtw likes this.
Weizilla is offline   Reply With Quote
Old 12-20-2017, 11:13 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,076
Re: Mud and/or Tape Top of Half Wall?
Some 1x8 with a rounded over edge is probably the best option.
Do you have access to a router and some bits?
Old 12-21-2017, 12:40 AM   #3
retired framer
Rewards Points: 22,104
Like this.
Old 12-21-2017, 06:17 AM   #4
retired painter
Rewards Points: 172
No, you just need to make sure that the trim under the cap [1x8] will set level and cover any unfinished drywall.
123pugsy likes this.
mark sr is online now   Reply With Quote
Old 12-21-2017, 07:14 AM   #5
Rewards Points: 18
I do not. I was just going to sand the corners a bit so they're not sharp but otherwise leave them square
Old 12-21-2017, 07:15 AM   #6
Rewards Points: 18
Nice. Saves me some work. Thanks!
Old 12-21-2017, 08:08 PM   #7
Rewards Points: 1,784
The molding you use under there should be the same molding you use around your windows and doors.
ChuckF. is online now   Reply With Quote
Old 12-22-2017, 05:12 AM   #8
Naildriver
chandler48's Avatar
Rewards Points: 4,602
Also, I would not "screw" the 1x8 down. Use 2" finish nails. That way it would be easier to cover the holes, especially if you don't plan on painting the top.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Need Some Advice About A House With An Issue neutropia General DIY Discussions 7 01-29-2017 06:46 AM
Basement half wall tekmonkey Building & Construction 1 12-24-2015 10:51 AM
Securing a Half Wall cbaur88 Building & Construction 18 02-18-2013 05:43 PM
Half wall help rodsteryz Remodeling 2 02-18-2012 12:11 AM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
