MH Wall Anchors 101 - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-28-2018, 09:24 PM   #1
Rewards Points: 50
MH wall anchors 101
I need an education on wall anchors for a manufactured home. Previous owner used 2x4 to attach towel racks and TP holder. We are redoing the bathroom and want to use anchors. What kind should I use ?
MH wall anchors 101-e735560f-abd9-43e0-8878-599724af2f1c.jpg   MH wall anchors 101-5d41b00b-e6a9-4ea8-9fed-734f933023ec.jpg
Tropicalcats is offline   Reply With Quote
Old 10-28-2018, 09:35 PM   #2
Re: MH wall anchors 101
Depends if there are young kids around. If yes, then I would use the metal collapsible anchors. Otherwise, the plastic anchors work fine. The metal ones seem to expand farther and hold better.
Sent from my SM-G900V using Tapatalk
cmwhitmoyer is offline   Reply With Quote
Old 10-28-2018, 09:59 PM   #3
Rewards Points: 50
No yongins in the house. So do you mean the metal toggle type.
Old 10-29-2018, 05:42 AM   #4
No this type. You can remove the screw and not lose the anchor.
Old 10-29-2018, 06:45 AM   #5
retired painter
Rewards Points: 1,372
I'm not positive that type of anchor will work well in a mobile home. The drywall in a MH is typically only 1/4" thick.
mark sr is online now   Reply With Quote
Old 10-29-2018, 07:09 AM   #6
There are different lengths. Some will collapse down smaller than 1/4".
Old 10-29-2018, 07:16 AM   #7
Rewards Points: 8,972
That's going to make just about any anchor difficult.
But if you are re-doing the bathroom anyways, you could cut a hole in the drywall, and put some 2 x 6 blocking behind drywall.
SPS-1 is online now   Reply With Quote
Old 10-29-2018, 07:19 AM   #8
Rewards Points: 50
That was my fear. The drywall may be to thin for a regular anchor. Do they make a thin wall anchors?
Old 10-29-2018, 07:22 AM   #9
ZTMAN's Avatar
Rewards Points: 410
I would be prepared to find a hole behind that 1x. Possible that that tp holder was originally mounted to the wall the way you want to do it and was ripped off, hence the 1x mounting solution.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 10-29-2018, 07:52 AM   #10
Rewards Points: 7,463
The metal toggle type has far more holding power than post 4 pic (hollow wall anchor).
It may not be an option in a MH. Even without children the constant pulling motion makes a TP holder a tough install unless you hit wood. A more attractive version of what you have or open the wall and add some wood is your permanent solution.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 05:53 PM
Retaining Wall Anchors kuhlman Building & Construction 1 03-07-2013 02:49 PM
Wall damage below bathroom quaker87 Plumbing 8 02-28-2013 05:56 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
