DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Drywall & Plaster (https://www.diychatroom.com/f101/)
-   -   MH wall anchors 101 (https://www.diychatroom.com/f101/mh-wall-anchors-101-a-644851/)
Tropicalcats 10-28-2018 09:24 PM
MH wall anchors 101
2 Attachment(s)
I need an education on wall anchors for a manufactured home. Previous owner used 2x4 to attach towel racks and TP holder. We are redoing the bathroom and want to use anchors. What kind should I use ?
cmwhitmoyer 10-28-2018 09:35 PM
Re: MH wall anchors 101
Depends if there are young kids around. If yes, then I would use the metal collapsible anchors. Otherwise, the plastic anchors work fine. The metal ones seem to expand farther and hold better.
Sent from my SM-G900V using Tapatalk
Tropicalcats 10-28-2018 09:59 PM
1 Attachment(s)
No yongins in the house. So do you mean the metal toggle type.
cmwhitmoyer 10-29-2018 05:42 AM
No this type. You can remove the screw and not lose the anchor. https://uploads.tapatalk-cdn.com/201...7226870235.jpg
mark sr 10-29-2018 06:45 AM
I'm not positive that type of anchor will work well in a mobile home. The drywall in a MH is typically only 1/4" thick.
cmwhitmoyer 10-29-2018 07:09 AM
There are different lengths. Some will collapse down smaller than 1/4".
SPS-1 10-29-2018 07:16 AM
That's going to make just about any anchor difficult.
But if you are re-doing the bathroom anyways, you could cut a hole in the drywall, and put some 2 x 6 blocking behind drywall.
Tropicalcats 10-29-2018 07:19 AM
That was my fear. The drywall may be to thin for a regular anchor. Do they make a thin wall anchors?
ZTMAN 10-29-2018 07:22 AM
I would be prepared to find a hole behind that 1x. Possible that that tp holder was originally mounted to the wall the way you want to do it and was ripped off, hence the 1x mounting solution.
Colbyt 10-29-2018 07:52 AM
The metal toggle type has far more holding power than post 4 pic (hollow wall anchor).
It may not be an option in a MH. Even without children the constant pulling motion makes a TP holder a tough install unless you hit wood. A more attractive version of what you have or open the wall and add some wood is your permanent solution.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
