How To Support New Drywall After Soffit Removal - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By HDS
  • 1 Post By Nealtw
Old 01-05-2018, 01:40 PM   #1
Rewards Points: 62
How to support new drywall after soffit removal
We removed a soffit and need to add wall and ceiling drywall where the soffit used to be. The existing ceiling drywall ends halfway between two trusses (24" O.C.). How do I support the existing and new drywall? Do I add perpendicular blocking between the two trusses (if so, at what spacing)? I'm using 1/2" sag-resistant drywall. Thank you.
kktalker is offline   Reply With Quote
Old 01-05-2018, 01:47 PM   #2
retired painter
Rewards Points: 172
Re: How to support new drywall after soffit removal
Ideally you'd cut it back to the next ceiling joist but you can add nailers attached to the joist that is showing and then screwed through the drywall to secure the other end.
mark sr is offline   Reply With Quote
Old 01-05-2018, 01:59 PM   #3
Rewards Points: 62
Thank you, Mark. I don't mean to be obtuse. Do you mean a 2x4 perpendicular to the trusses that is attached to the visible truss at one end and the existing drywall at the other? What spacing would I need between the nailers?
Old 01-05-2018, 02:23 PM   #4
HDS
Rewards Points: 318
Personally I'd just cut the drywall back to the next truss, tack on a 2x4 to that truss (parallel to it) to have a nailing surface.
mark sr likes this.
HDS is online now   Reply With Quote
Old 01-05-2018, 02:23 PM   #5
retired framer
Rewards Points: 22,120
You would block it 24" OC but that edge was an inside corner, you will have a nightmare trying to get a smooth fill. I would cut it right beside the next truss and add another 2x4 to the side of the truss.
mark sr likes this.
Drywall Damage After Wallpaper Removal katega Drywall & Plaster 1 01-28-2012 10:11 PM
Drywall Damage After Wallpaper Removal katega Painting 10 01-26-2012 10:21 PM
Single Hung Window Removal for Drywall bparise Drywall & Plaster 2 12-12-2009 07:44 AM
Complete drywall removal - old house diverdaveman Building & Construction 5 06-22-2007 03:17 PM
Drywall or Wallpaper removal? Slicendice Remodeling 3 03-16-2005 05:41 PM
