How To Finish Gap Between Wall And Tile Column - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By Windows on Wash
Old 10-17-2017, 03:33 PM   #1
Rewards Points: 62
How to finish gap between wall and tile column
Hi guys, I'm stumped on this one. There is a gap behind some vertical tile I have around a fireplace (attached attached. It goes from about 1/8 inch at the bottom all the way up to 3/8 and pushing 1/2 inch at the top. I put backing rod in to fill out the gap towards the outer edge and to make it even. I was going to buy some latex caulking to do the edge and then paint it to match the wall , but the guy at the local Home Depot suggested I use spackling to fill it in. But I would worried about it cracking if the tile settled at all.
What do you guys think?
Thanks so much
B
How to finish gap between wall and tile column-img_20171017_160339_1508272373456.jpg   How to finish gap between wall and tile column-img_20170919_062618_1508272428628.jpg
Boogityman is offline   Reply With Quote
Old 10-17-2017, 04:22 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 12,450
Re: How to finish gap between wall and tile column
Backer rod and a taped off caulk line would probably be the cleanest and least obtrusive.
Mike Milam and chandler48 like this.
Old 10-17-2017, 04:42 PM   #3
Mike Milam's Avatar
Rewards Points: 212
And least apt to crack.
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is offline   Reply With Quote
Old 10-17-2017, 05:52 PM   #4
retired painter
Rewards Points: 1,374
Backer rod and caulk or piece of molding to hide the gap.
mark sr is offline   Reply With Quote
Old 10-17-2017, 07:23 PM   #5
Rewards Points: 62
Awesome, thanks guys. I was ready to do it this way but the Home Depot guy really threw me off. I would like to be able to paint and for the gap size Latex caulk seems to be best. But at the same time, I'm worried about it eventually drying and cracking as it's about 18 inches from a gas fireplace at the closest. It doesn't throw off an incredible amount of heat but it's not nothing. Should I be looking for any product in particular?
Thanks again, you all are awesome
Old 10-18-2017, 07:39 AM   #6
Rewards Points: 1,046
you want a caulk that stays flexible when dry. and clean out that old stuff.
Fix'n it is online now   Reply With Quote
How do I finish tiled shower @ tile meets wall? Tgiambattista Kitchen & Bath Remodeling 3 05-24-2017 06:33 PM
Bathroom Wall Tile Questions TheBigPig Tiling, ceramics, marble 7 11-08-2016 01:13 PM
Drain tile questions for retaining wall installation. Tmaxx1 Landscaping & Lawn Care 11 06-10-2011 11:17 AM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
