How Do I Fix My Out Of Level Ceiling Corner? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-04-2015, 10:09 AM   #1
Rewards Points: 34
How Do I Fix My out of Level Ceiling Corner?
I'm installing a corner shower (tile). I didn't realize before I started installing the tile that the corner is 3/8" higher than the outside of the tile.
The ceilings and walls are already finished/painted with the exception of the top row of tiles.
Can I float out some mud from the corner? If so, what mud should I use? Durabond?
Thanks for your help!
clineco is offline   Reply With Quote
Old 11-04-2015, 11:38 AM   #2
Rewards Points: 54
3/8" seems like a lot of mud to put down. Just random idea: glue up a small piece of 1/4" drywall into the corner and then level it out to the rest of the ceiling with mud?
wetech is offline   Reply With Quote
Old 11-04-2015, 09:27 PM   #3
Rewards Points: 2,048
No idea hat you mean about the corner being 3/8" higher than the outside tile? Pix??
ront02769 is offline   Reply With Quote
Old 11-04-2015, 10:04 PM   #4
Rewards Points: 34
Looks like the attached.
The Following User Says Thank You to clineco For This Useful Post:
ToolSeeker (11-05-2015)
Old 11-04-2015, 10:23 PM   #5
Rewards Points: 302
this and this don't fit together. but if i go just on the pic = just trim the tile so that it has an even gap across the top.
Fix'n it is offline   Reply With Quote
Old 11-04-2015, 10:37 PM   #6
Rewards Points: 30
Either get the tile bull nosed and stop it short or cut the tiles to create an eve gap.
bmathews is offline   Reply With Quote
Old 11-05-2015, 12:40 AM   #7
Rewards Points: 34
Why is floating the ceiling even not an option?
Old 11-05-2015, 07:01 AM   #8
Rewards Points: 6,236
To fill this area with mud is about the only solution I can think of off hand. I don't think 1/4" drywall will work because you can't taper drywall and if you cover the entire ceiling the tile in front is not going to look right.
And to use a small piece of bullnose in the open space again will really look funny. Even a piece of trim wouldn't look right because of the slope. Put on a couple coats of Dura Bond to build it up, getting it as smooth as you can, then finish it with regular joint compound.
Entering your general location can help with answering a lot of times
Old 11-05-2015, 08:37 PM   #9
If the OP messes with the ceiling on that END, then it needs to be dealt with on the adjoining side wall. Probably blasphemy...but color match caulk in the area will blend in and no one will notice the joint. Ron
ceiling drywall has a bit too much mud in corner dfphoto Drywall & Plaster 3 07-25-2015 07:56 PM
Corner bead on a recessed ceiling jackrobat Drywall & Plaster 5 03-25-2011 09:42 AM
Apartment water leak - questions haris General DIY Discussions 2 03-23-2011 07:26 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
How do I get my ceiling level? Leah Frances Building & Construction 4 01-10-2009 01:12 PM
