Homax Orange Peel Spray Texture In A Can - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By mark sr
Old 10-06-2017, 08:37 AM   #1
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 1,182
Homax Orange Peel Spray Texture in a Can
In this short video clip Iím demonstrating how to spray a can of Homax oil base orange peel texture on an actual drywall patch where I installed about 32 sqft of new drywall.
I think the spray can texture is Great for DIY texture matching!!
Iím spraying the orange peel texture on new drywall and the transition where the new drywall meets the old drywall and existing texture. I had to open up a wall to install some wood framing to support the Big Screen Plasma TV. The area has a medium orange peel that I need to match. Iíll be spraying this entire area with just one can of the Pro Grade Homax Orange Peel Texture.
**Be sure to shake the can well before trying to spray the orange peel texture!
All i can say is cover everything that you donít want texture to get on in the surrounding area around the repair that youíre going to be spraying the texture on.
**Caution**- Always wear safety glasses and a respirator whenever spraying the can of oil base texture. Try and ventilate room by opening windows and doors.
Thanks for watching this how to match orange peel texture video tutorial!
-Paul
More info on my website---> http://www.texturemaster.com/communi...x-texture-can/
-Paul
Checkout my YouTube Channel with 90,000 Subscribers and over 13,000,000 Views
https://www.youtube.com/paulpeck
Sir MixAlot is offline   Reply With Quote
The Following User Says Thank You to Sir MixAlot For This Useful Post:
tresstylez (10-23-2017)
Old 10-06-2017, 12:18 PM   #2
retired painter
Rewards Points: 1,332
Re: Homax Orange Peel Spray Texture in a Can
worth repeating
All i can say is cover everything that you don’t want texture to get on in the surrounding area around the repair that you’re going to be spraying the texture on.
Sir MixAlot likes this.
mark sr is online now   Reply With Quote
Tags
diy , drywall patch , homax orange peel texture , orange peel , texture
Not exactly orange peel Startingover Painting 3 10-02-2017 09:16 PM
Spraycan orange peel. Beepster Drywall & Plaster 2 03-01-2014 11:29 AM
Knockdown ceiling : My walls are orange peel.. Arkanoid Remodeling 4 08-07-2007 12:23 PM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 03:38 PM
What to use to spray texture on new drywall? klemmy Remodeling 16 03-28-2007 06:14 PM
