Hanging Drywall On Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By KHouse75
  • 2 Post By Nealtw
  • 1 Post By eddy75
Old 09-14-2017, 12:26 PM   #1
Rewards Points: 26
Hanging drywall on ceiling
Hi there,
I'll be hanging drywall in the basement ceiling in the next week or so but not sure what direction to lay it.
I have prepped the ceiling by installing 1 x 3 stripping perpendicular to the floor joist on 16" center.
Would I ....
A: Hang the drywall perpendicular to the stripping (parallel to the joist) so
the butt ends will end/begin on the stripping.
B: Hang the drywall parallel to the stripping (perpendicular to the joist) so
the tapered ends will end/begin on the stripping.
eddy75 is offline   Reply With Quote
Old 09-14-2017, 01:07 PM   #2
Rewards Points: 1,251
Re: Hanging drywall on ceiling
Drywall is three times stronger in the long direction so it's recommended to hang perpendicular to what you are screwing it to. In your case that would be perpendicular to the furring strips.
The USG handbook says when hanging 1/2" drywall on a ceiling perpendicular, you can have framing spacing of 24 inches. When hanging parallel, you can only have 16 inches.
MTN REMODEL LLC likes this.
KHouse75 is offline   Reply With Quote
The Following User Says Thank You to KHouse75 For This Useful Post:
eddy75 (09-14-2017)
Old 09-14-2017, 01:11 PM   #3
retired framer
Rewards Points: 13,090
I agree, across the strapping or with the joists now.
MTN REMODEL LLC and mark sr like this.
Old 09-14-2017, 02:13 PM   #4
Rewards Points: 26
Perpendicular to the furring strips it is. Thank for the info!
Nealtw likes this.
Old 10-02-2017, 07:56 AM   #5
Rewards Points: 26
I started to hang the drywall on the ceiling but noticed that I may have a problem once I start the walls.
The furring strips are 3/4" thick and the drywall is 1/2" = 1 1/4". When I start the walls, I will only have about 1/4" space left on the top wall stud to attached a screw into. So I think I have enough space to support the drywall but not enough to be able to attached a screw. I will only be able to secure the drywall with on the bottom and side studs (24" apart).
Is this going to be a problem? Will/should I need to add another stud to the top to screw in the drywall or should I start to hang the drywall on the walls before the ceiling?
Old 10-02-2017, 08:02 AM   #6
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,762
I would just add 3/4 or so (or 1 1/2 ) nailers between the studs.
MTN REMODEL LLC is offline   Reply With Quote
Old 10-02-2017, 08:16 AM   #7
Rewards Points: 898
Every 24" is fine. Use drywall glue. My hangers put maybe 20 screws (all but 2 on the edges) in a 4'x16' sheet when using glue.
BIG Johnson is offline   Reply With Quote
Old 10-02-2017, 08:27 AM   #8
retired painter
Rewards Points: 1,374
It's easier to use nails along the perimeter, start the nails before you lift the sheet up, knock them in and then switch to screws. The tape and mud will help prevent those nails from popping later.
mark sr is offline   Reply With Quote
Old 10-02-2017, 10:09 AM   #9
Rewards Points: 26
Thanks for the input.
Old 10-02-2017, 10:12 AM   #10
Rewards Points: 1,311
The drywall does not need to be nailed to the top plate. To the studs is enough. Use glue as mentioned to reduce the number of fasteners.
XSleeper is online now   Reply With Quote
Old 10-02-2017, 10:19 AM   #11
Rewards Points: 26
I'm not sure if I can use glue. I have a vapor barrier on the wall studs.
Old 10-02-2017, 10:43 AM   #12
Rewards Points: 2,242
Why did you elect to use a vapor barrier over the studs? Is there fiberglass insulation in the stud cavities? Is there rigid foam against the concrete?
I know, bad timing, but had to ask.
Bud
Bud9051 is online now   Reply With Quote
Old 10-02-2017, 11:28 AM   #13
Rewards Points: 26
The outside perimeter walls were prepped by the builder. They erected the walls, added fiberglass insulation and covered it with vapor barrier.
Old 10-02-2017, 12:45 PM   #14
So, you have foundation, stud walls, cavity filled with fiberglass insulation, plastic vapor barrier, and it will be covered with drywall.
Some details: I don't see where you are but I assume it is a cold climate. In addition to moisture vapor passing through the foundation a cold climate will have a condensation problem with warm humid basement air seeping through that fiberglass and reaching a cold foundation wall. Best practices now like to recommend a layer of rigid insulation so that the first non-permeable layer and air will hit will be above the condensation temperature (the dew point). I'll add a link below and reference a photo of your wall assembly.
Now, to put that into perspective, the results they show are not guaranteed, just more probable than if the rigid were used and vapor barrier were omitted. Since I have no other information about your basement, how it was constructed, or other moisture/water issues I cannot predict an outcome.
Take a look at photograph #2 in the link below.
https://buildingscience.com/document...ts?full_view=1
Bud
Old 10-02-2017, 02:37 PM   #15
Rewards Points: 898
Just an FYI, primed and painted drywall is an acceptable vapor barrier.
What's done is done, Just use more screws.
http://buildingincalifornia.com/wp-c...lChecklist.pdf
Tips for Hanging Drywall Up Against Wavy Ceiling hboogz Drywall & Plaster 9 11-26-2013 09:12 AM
drywall or sheetmetal ceiling drmax Building & Construction 12 09-21-2012 08:15 AM
Hanging Ceiling Drywall Lollymagoo Drywall & Plaster 9 04-16-2012 08:50 AM
Drywall ceiling above bathtub/shower larabiec Drywall & Plaster 3 06-26-2011 01:23 PM
drywall ceiling repair after bathroom fire help nilewaves Drywall & Plaster 9 06-07-2011 03:33 PM
