Great Stuff Except When It Gets On Vinyl - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By ront02769
Old 12-22-2017, 01:59 PM   #1
Rewards Points: 26
Great Stuff except when it gets on Vinyl
Our remodeling contractors got Great Stuff Window and Door Insulating Foam Sealant on our white vinyl sliding door frame. According to Great Stuff's instructions, now that it has cured, the foam sealant will have to be removed mechanically.
Any advice for doing this with minimal damage to the vinyl?
SM_Jeff is offline   Reply With Quote
Old 12-22-2017, 02:23 PM   #2
Rewards Points: 6,470
Re: Great Stuff except when it gets on Vinyl
I'm guessing "mechanically" means sanding.
Since the vinyl isn't that thick, start fine and finish even finer. No power tools as the vinyl probably wouldn't take any heat.
Bud
Bud9051 is offline   Reply With Quote
Old 12-22-2017, 02:54 PM   #3
Rewards Points: 1,376
Vinyl doesn't much like to be sanded. As a first shot, I'd try some goof off. Ron
Mike Milam likes this.
ront02769 is offline   Reply With Quote
Old 12-22-2017, 03:03 PM   #4
They make a solvent for great stuff but I assume that it would also attack the vinyl. Not sure what the chemical is but it is in the cleaner they sell for the foam guns.
You might test a spot with bleach to see if it has any affect.
Has the contractor made any offers, like replacing the door?
Bud
Old 12-22-2017, 03:22 PM   #5
Rewards Points: 2,122
Maybe test a spot with WD40 ? My favorite go to cleaner and fix all. JMO
Gregsoldtruck79 is offline   Reply With Quote
Old 12-22-2017, 03:54 PM   #6
retired painter
Rewards Points: 192
I'd try a stiff rag along with either detergent or a mild solvent like WD-40. A plastic putty knife might also help.
Any reason you can't get the contractor to clean up his mess?
mark sr is online now   Reply With Quote
Old 12-22-2017, 04:29 PM   #7
Ron's suggestion of goof off shows up in this link as well.
https://www.dailykos.com/stories/2010/12/11/928154/-
Bud
Old 12-22-2017, 04:34 PM   #8
jlhaslip's Avatar
Rewards Points: 708
Might also try Agent Orange the waterless hand cleaner.
It works for lots of stuff and has no harsh chemicals. Agree with those who suggest a stiff rag or even a pot scrubber as an applicator.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Great Stuff expansion foam around Hydronic Baseboard Heater TFuller HVAC 5 05-27-2015 04:22 PM
Weatherproofing - Great Stuff vs Caulk. Mold Issue. cjaustin81 General DIY Discussions 17 11-19-2014 05:23 PM
Insulation 'Great Stuff' by DOW Chem. jh1999 Insulation 21 12-01-2011 02:12 PM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 05:15 PM
