Easiest To Cut Cement Board - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree9Likes
  • 1 Post By BIG Johnson
  • 2 Post By chandler48
  • 1 Post By ryansdiydad
  • 2 Post By ront02769
  • 3 Post By Windows on Wash
Old 10-07-2017, 03:08 PM   #1
Rewards Points: 956
Easiest to cut cement board
I've got to install 1/2" cement board in my shower and I'd like to know which brand is easiest to cut. I'm assuming they are all equally good for shower wall use
Hardiback
Durock
Wonderboard lite
Thanks in advance.
jaketrades is offline   Reply With Quote
Old 10-07-2017, 03:13 PM   #2
Rewards Points: 898
Re: Easiest to cut cement board
Hardiback
Durock
Wonderboard lite
Thanks in advance.
Out of those; definitely not Hardi. That stuff sucks to cut. Durock is easy, never used Wonderboard but it looks like Durock. Greeneboard is easy to cut and permabase is about the same as Durock but is heavier.
jaketrades likes this.
BIG Johnson is offline   Reply With Quote
The Following User Says Thank You to BIG Johnson For This Useful Post:
jaketrades (10-07-2017)
Old 10-07-2017, 03:22 PM   #3
Rewards Points: 956
I recall Hardibacker was destroying my jigsaw blades.
Old 10-07-2017, 04:14 PM   #4
Naildriver
chandler48's Avatar
Rewards Points: 2,932
Cut it with either a backer blade on your circle saw or with a 4" grinder with a 4" tile blade.
http://www.homedepot.com/p/Avanti-Pr...6CHR/203914961
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 10-07-2017, 04:58 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 12,384
It’s messy, but the cleanest cuts on cement board are with a grinder and a 4” blade as @chandler48 mentioned.
Old 10-07-2017, 05:05 PM   #6
Rewards Points: 1,528
Or score Hardi board and snap it... for a shower I'd think scoring and snapping would be good enough...
mark sr likes this.
ryansdiydad is offline   Reply With Quote
Old 10-08-2017, 07:24 PM   #7
Rewards Points: 1,912
If you read the instructions on the hardi, it says do NOT cut it with a circular saw, jig saw, or any other kind of saw. Spend five bucks at the bog box and buy a carbide scorer and just score and snap the hardi. VERY easy, even the holes for the spigot, handle, whatever. Ron
kwikfishron and jaketrades like this.
ront02769 is offline   Reply With Quote
Old 10-08-2017, 08:30 PM   #8
As a point of clarification, when I said “cement board” I was referring to duroc and other cementious boards vs hardie backer. Hardie cuts fine with the carbide scoring blade, but I would always take duroc over a Hardie board.
Anytime you are cutting anything with portland or silica, you need proper PPE.
Old 10-09-2017, 05:59 AM   #9
Rewards Points: 956
I went with wonderboard lite. I had to bring in 7 sheets of 1/2 (7/16”) and 3 sheets of 1/4” myself. Wanted to save my back.
Old 10-09-2017, 06:00 AM   #10
Rewards Points: 956
I’ve tried to score and snap 1/4” hardibacker with a Home Depot carbide tip blade. I had to cut like 4” off and it was a pain to do with that blade. Maybe the blade was shot.
This stuff:
Old 10-09-2017, 09:16 PM   #11
Score multiple times and bend TOWARDS the score, exactly the opposite of the way that you do Sheetrock. Ron
Old 10-09-2017, 09:38 PM   #12
Rewards Points: 898
Score multiple (50+) times Ron
No thanks. I'll Score Durock once.
Old 10-10-2017, 08:44 PM   #13
Weak hands and wrists ;-) Couple of scores with carbide cutter for me, put a two bye under the part you're going to keep and just bend over that. While I PREFER durock, I often have to work with what is donated....and often it is hardi. And yeah, you've gotta hit it with a wet sponge before you put put thinset on it else it will suck out the thin set's moisture. Ron
Old 10-10-2017, 09:03 PM   #14
I still like concrete over fiber cement. There are going to be a bunch of sick people that worked with FC thinking it was just dust.
Cement board on a slab? gwilkrrs Tiling, ceramics, marble 6 11-14-2013 07:20 AM
Type nails? - wooden trim into cement board Easypick Carpentry 5 07-21-2013 03:16 PM
yet another cement board question echobravo Kitchen & Bath Remodeling 4 01-23-2012 04:39 PM
Installing Stone Veneer to cement board on a wall Augy Building & Construction 2 01-20-2012 06:17 AM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 06:29 PM
