Drywall Over OSB + Electrical Question - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By huesmann
Old 04-24-2019, 08:48 AM   #1
jb9
Rewards Points: 198
Drywall over OSB + Electrical Question
Hello,
I am getting ready for an electrical inspection and I need to have my lighting boxes installed. My solution is to put my lighting (pancake) boxes inside ledger boards which will be surface mounted (over drywall). The reason for this is so I don't have to make a mess of my SIP panels (they are expensive). If I drill holes and mount my fixture ledger boards onto the OSB for the inspection, is there a way re-locate my mounting holes accurately after I put up the drywall and then remount the fixture ledger board? I have read about tricks using a nail or a screw with the head cut off to perhaps mark/scribe the hole during installation but I'm wondering if anyone has any other thoughts. I may try and ask the inspector if he will let me wait to install the ledger boards until the final inspection. That may not fly though...
jb9 is offline   Reply With Quote
Old 04-24-2019, 08:57 AM   #2
Rewards Points: 1,915
Re: Drywall over OSB + Electrical Question
Is your question "how to accurately transfer the hole location to the drywall after closing up the hole?"
finisher65 likes this.
huesmann is offline   Reply With Quote
Old 04-24-2019, 09:59 AM   #3
jb9
Rewards Points: 198
Yes. That's what I'm after. Just wanted to give some background on what I am trying to accomplish.
Old 04-24-2019, 10:01 AM   #4
retired framer
Rewards Points: 16,614
The box should stick out 1/2 from the OSB
Do not use flat bottom gables with scissor trusses.
Old 04-24-2019, 10:52 AM   #5
jb9
Rewards Points: 198
I'm using a 1/2"pancake box routed into a ledger board so I don't have to destroy the OSB.
Old 04-24-2019, 07:46 PM   #6
Usually Confused
lenaitch's Avatar
Rewards Points: 1,902
Not directly on topic, but are you legal with pancake boxes? They have very limited box fill capacity (something like a single 14/2) and you mention "lighting boxes" which suggests a run of connected conductors. I don't know if the canopy/base of the fixture can be used as box volume.
_________________________________________
Who Dares Wins
lenaitch is offline   Reply With Quote
Old 04-25-2019, 09:09 AM   #7
How about you mark the opposite walls on each side thru the center of the hole, and measure the distance to the center of the hole? Once the drywall is up, measure back to the center of the hole.
Old 04-25-2019, 10:17 AM   #8
jb9
Rewards Points: 198
That could work. To answer the previous question, all fixtures will terminate with a 14-2 Romex so the 6 cubic inches of the boxes will be sufficient.
The goal is to avoid destroying my SIP panels.
Painting and Drywall question - Areas of exposed drywall core In Ontario Painting 13 03-27-2019 11:24 AM
Electrical sub panel question Avery4 Electrical 13 12-05-2018 10:06 PM
Question regarding drywall or plywood Jax2 Drywall & Plaster 14 11-22-2017 05:19 AM
Electrical loading question jimcorey Electrical 2 12-08-2012 07:27 AM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
